s300 completely dead..
Old Mar 30, 2010 | 09:05 PM
TehGhett0P1mp's Avatar
Default s300 completely dead..
Hello it seems somehow my s300 and my ecu got damaged a component on q34 on a p72 ecu is fried. Also the s300 will not light up or anything when placed into a good working ecu I am posting the pictures in hope someone can shed some insight on how screwed I am or if the s300 can be repaired.
Physically it looks just fine, no burns anywhere on it but I just wanted to ask ive done electronics repair before but usually there are physical signs of damage. This time is nothing.
Anyways I added the pics showing the damage to the ecu and pictures of the s300, hopefully someone can chime in.
Thanks
Old Mar 30, 2010 | 09:24 PM
HRTuning's Avatar
Default Re: s300 completely dead..
Hondata will look at and possibly repair the S300 for a fee, I believe. If there's extensive damage I think you may need to purchase a new one. I'd give them a call to find out for sure.
Old Mar 30, 2010 | 09:31 PM
mtber's Avatar
Contact the dealer you purchased the system from for information on the Hondata warranty.
99% of the time that q34 is burnt it is because the customer has something improperly wired/hooked up on your engine harness which caused the failure.
Check your EGR/Intake air temperature wiring.
Also, check your intake air temperature sensor as it may also be damaged.
Old Mar 30, 2010 | 09:32 PM
Yeah I saw a email on their site and I sent it their way to see how the process works, I found the component on the ecu on xenocrons site so I might be able to save the ecu if nothing else.
Thank you for the input I will look for a number on their site if they do not reply quickly via email.
Old Mar 30, 2010 | 10:31 PM
mtber's Avatar
Replacing the component probably won't fix the ecu/issues you are having....
Old Mar 30, 2010 | 11:07 PM
HRTuning's Avatar
Q34 blowing shouldn't have caused any damage to the S300. If you installed it into a known good ECU and it still doesn't work there is definitely a problem!
Old Mar 31, 2010 | 09:56 AM
So replacing q34 wont do anything? Because I was able to find the part on Xenocron's site I am aware it wont magically fix the s300 but if I can get the ecu to work it will help make the situtation a little better.
Or is there another reason you think that it cannot be repaired? Not saying you are wrong just attempting to get some insight.
Old Mar 31, 2010 | 09:59 AM
The only thing I can think is it either blew during driving, or it blew when I unplugged the ecu after I stopped to swap out the s300 out of my old ecu. I know the car was off but maybe the accessorys were on and thats what caused it to short everything out.
It was late last night so I tried it again this morning and there was no lights on the s300 but when I plugged it in the PC via usb the PC did detect it but saw it as a unknown device and could not configure it. =(
Old Mar 31, 2010 | 10:15 AM
HRTuning's Avatar
Shame on me for not realizing we were talking about the wrong component. Q31 is the one that the PCS uses, not Q34. Sorry!
Old Apr 1, 2010 | 12:43 PM
But its q34 thats blown =p but anyways I guess I had the s300 installed by off a prong because I got it to work after I installed it again.
The burnt ecu works as well is not throwing any CELs or anything..I checked the IAT sensor and the wiring and everything is okay so I am not sure what happened..
Either way thanks for putting up with my stupidity haha
Old Apr 1, 2010 | 03:25 PM
HRTuning's Avatar
No worries man. Glad it still works!
EGtoua
Engine Management and Tuning
Apr 28, 2010 03:28 PM
vy3tnamezz
Sep 20, 2009 10:43 AM
b20izzle
Dec 6, 2004 09:22 AM
BoostedH23a1
Jun 26, 2003 03:32 AM
