Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Electrical Issue help
Old Nov 15, 2017 | 05:34 PM
BCivs03's Avatar
Default Electrical Issue help
I have a 03 Honda Civic LX sedan and my lights dim and my dash gauges go up and down then stays down. Car drives fine then once I shut it off, the car won't start it just clicks rapidly but I just got a brand new battery and I got the alternator replaced but I don't know if it's a faulty alt or something else also my car idles close to 2 rpm and will go to 1 rpm then slowly decrease. Pls help I have no idea what to do
Old Nov 16, 2017 | 05:28 PM
toyomatt84's Avatar
Sanji
Default Re: Electrical Issue help
It looks like you may have a CEL active. Have you had the codes pulled?
Old Nov 16, 2017 | 07:11 PM
BCivs03's Avatar
no not yet I was gonna take it up to advanced to get the codes pulled but the check engine light been on for awhile and I thought it was because of my gas cap.
Old Nov 16, 2017 | 11:13 PM
holmesnmanny's Avatar
did you replace the alternator before or after this started happening ? specifically where did you get the alternator ?
Old Nov 17, 2017 | 04:23 AM
BCivs03's Avatar
After it happened because my car was perfectly fine until I jumped some one vehicle and the day after my car starts acting up and I got the alt from like a place that gets wrecked cars and they take the parts off and resell them
Old Nov 17, 2017 | 08:26 AM
NDNV's Avatar
When boosting a car battery follow this rule:
‘Red from the dead, to red on the good.
Black from the good, to under the hood.’
Red positive on the discharged battery to the red positive on the boosting car battery (while car is running).
Black negative on the boosting battery to the chassis or ground cable of the discharged vehicle. (Never to the black negative of the discharged battery!)
Just in case you boosted incorrectly and caused your issues.
Old Nov 17, 2017 | 08:30 AM
BCivs03's Avatar
Do you have any ideas of why my car is acting strange but thank you for that tip
Old Nov 17, 2017 | 08:59 AM
have your car scanned for codes
Old Nov 17, 2017 | 09:03 AM
BCivs03's Avatar
Okay I'll have to do that tomorrow since I had to get a ride but I'll check that out, thank you I appreciate it
Old Nov 17, 2017 | 10:59 AM
NDNV's Avatar
I have had electrical problems before and it eventually was the alternator and the alternator ground. The ground for the alternator is the bolt and bracket that adjusts the tension of the alt belt. That bolt causes issues with proper grounding and electrical issues.
Get the CEL code and report back as mentioned already.
Old Nov 17, 2017 | 03:50 PM
BCivs03's Avatar
Okay I'll get it checked out and let you guys know tomorrow what I get back, thank you for all you guys help I appreciate it
mproost
Honda Civic (2006 - 2015)
Jan 16, 2019 05:54 PM
attica
14
Apr 28, 2010 12:02 PM
h22_crx
12
Jun 3, 2009 01:27 PM
sanimalp
28
Jul 28, 2008 02:35 PM
Eghatch93
Feb 1, 2006 05:52 PM
