Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
02 Civic Engine light
Old 09-05-2017, 05:38 AM
phed's Avatar
Default 02 Civic Engine light
My car is a 2002 Civic. Recently, the engine light turned on. I went to a garage to replace the rear sensor, but the engine light still come up after a couple of days driving. The technician there said I may need to replace the front sensor as well but that is a rare case and not cheap. Any suggestions?
Old 09-05-2017, 10:48 AM
prodjay10's Avatar
Default Re: 02 Civic Engine light
What is the code? Do you know what was replaced? I don't think there is such a thing as a rear sensor.
Old 09-08-2017, 04:22 AM
phed's Avatar
I did not ask about the code. The technician replaced a sensor that control the emissions between the rear tires.
Old 09-12-2017, 04:51 AM
phed's Avatar
I asked the code was 1456, any comment?
Old 09-12-2017, 09:04 PM
Sanji
toyomatt84's Avatar
Either a fuel filler cap isn't sealing or a possible leak in the filler neck, could easily be the problem at hand.
Old 09-13-2017, 05:03 AM
phed's Avatar
Each time after I filled up the gas, I tightened the cap carefully by hearing at least three clicks.
Can the gasket affect it? The technician mentioned that the gasket starts to loose.
Old 09-13-2017, 08:21 PM
Sanji
toyomatt84's Avatar
There's a good video out there on the P1456 code, and the fuel filler neck seal issue.
Old 09-16-2017, 07:32 AM
magog45's Avatar
On a 2002 at this point you might want to look at the vent valve solenoid.
Kodyc
02-03-2017 01:14 PM
tegged
07-15-2016 08:28 AM
90Rexx
Acura TSX
11-03-2012 04:15 AM
hondabinge
04-12-2011 02:13 PM
samuel_gatech
08-26-2006 01:56 PM
Quick Reply: 02 Civic Engine light
