Defrost issue
Defrost issue
My ac works. The air blows. In the mornings, when I pull from the garage, my windows fog up. When I turn the defrost on, it blows cold air, like the ac is on. I make sure that the ac isn't on or the recycle. After I get a few miles away from home, all of a sudden the defrost starts working. Any ideas?
Re: Defrost issue
The A/C is automatically turned on when you use the defrost setting on the mode dial.
If it is too cold for you, adjust the temperature control dial.
See excerpt from owner's manual:
Re: Defrost issue
I'm stumped.
Sanji
Re: Defrost issue
That won't make the engine's coolant magically change from cold to hot. The reason your defrost is cold when you just started the car, is because it functions off of the coolant in your engine via the heater core. So, until the engine is warm, you won't get any heat inside the cabin of the vehicle.
Frizou
08-15-2017 06:48 AM
