Is there coolant in the small rubber line on the idle control valve?
Is there coolant in the rubber line on the idle control valve on a 2004 em2
Bump
Bump
Sanji
Re: Is there coolant in the small rubber line on the idle control valve?
There's more then one rubber line connected to the throttle body assembly. If you're sure its connected to the IACV, its probably a vacuum line. If its the two lines on the left of the throttle body, its the rotary air control valve that operates using coolant.
Here's a pic of the lines I'm referring to:
