Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Advice on larger size tire, 2005 LX Sedan
Old 01-07-2018, 01:33 PM
Guitargeak99's Avatar
Default Advice on larger size tire, 2005 LX Sedan
Hi all. First time poster here.
My current OEM tires are 195/60R15, and I would like to attempt to make the ride on my Civic a little smoother by increasing the side wall height.
My local tire shop suggested a 205/60R15 tire.
I realize that my results might be negligible, but do you tire guys out there think that these tires will fit ok without rubbing?
I’m old school and never really liked the “low profile thing” on tires anyway.
Thanks
Old 01-07-2018, 07:02 PM
Sanji
toyomatt84's Avatar
Default Re: Advice on larger size tire, 2005 LX Sedan
The 205/60/15's will fit just fine. They're within a safe tolerance from factory sizing, as well (at 1.95% oversized).
Old 01-07-2018, 07:18 PM
Thank you. My next 5000 mile tire rotation I’m going to pull the trigger.
Old 03-23-2019, 05:57 PM
This thread is over a year old, but I thought I would post back:
Installing these larger tires was a good move. This car rides better - the tire shop said that they have put these larger tires on Civics before.
Regards
Old 03-23-2019, 07:52 PM
JRCivic1's Avatar
Thank you for sharing your observations and results. When a member has posed a question like this, it is rarely followed up at some later date with any update... positive or negative.
Old 03-31-2019, 05:23 AM
MQAcuraEL's Avatar
Did you change rims or keep your stock ones? Just got a 2002 acura el for my nephew and the stock tire size is 185 65 15. For summer tires I was going to get him 195 60 15s. Now you have me wondering, but I think they will be fine. A 60 sidewall these days is actually a fair bit.
Old 03-31-2019, 07:16 AM
I just kept the stock rims.
The tire shop assured me that they had done this upgrade before on older Civics.
After the larger tires were installed they stayed out in the parking lot to make sure I had front tire clearance when turning the steering wheel.
It rides better with the extra sidewall (the factory sized tires where like little bicycle tires), and it did not affect the speedometer reading.
Good luck
Old 04-01-2019, 03:11 AM
MQAcuraEL's Avatar
Well, the sidewall difference between both sizes as compared to the original is 3mm. With the 195 you wind up with 3mm less sidewall than OE and with your 205 you gain 3mm. It's not that different, but I gather the increase of 6mm between the 195 60 15and the 205 60 15 can be felt. I think I would notice a bigger difference in handling between a T and H rated tire. It would be fun to be able to try a bunch of different sizes but reality is limiting so I will stick with the more regular zero plus sizing for the handling and braking benefit. Thanks for sharing your experience.
spenceyd
Honda Civic (2006 - 2015)
08-14-2017 04:38 PM
TurboTeG4
02-15-2010 12:34 PM
SlowEJ8
07-21-2009 01:25 PM
Rzoops
11-21-2005 11:58 AM
Flux
04-24-2002 09:09 PM
Quick Reply: Advice on larger size tire, 2005 LX Sedan
