2004 civic heater issue
need some help fixing the heater in my civic.
Blower does not work.
Checked the transistor and there 1.5(1500) ohm resistance between 2 of the posts
there is power to the blower.
pulled the blower motor and jumpered straight to 12v and it turns on
where do I look next?
Re: 2004 civic heater issue
1. a. Unplug the electrical connector to the transistor unit.
1. b. Attach a jumper wire (short piece of wire) from the Blue/Black wire cavity to the Black wire cavity on the unplugged electrical connector. Leave the connector unplugged.
1. c. Turn the ignition ON.
Does the motor run? If it does, there are no issues with the fuses or the blower motor relay.
2. Although the resistance of 1,500 ohm is okay for the blower motor power transistor, there are still other test before you can rule out the power transistor.
Part 1 -How to Test the Blower Motor Power Transistor (2001-2007 Honda Civic)
Hi tech8.
The blower motor runs runs with the jumper in place.
Does this mean it is indeed the transistor?
Thanks for for the help this is great!! What are my next steps.
Thanks for the helps guys. I picked up a transistor yesterday at the local wreckers and it worked for the night. I came out this morning and the fan is no longer working. I find it to coincidental that it would just fail so quick, so I am wondering what would case the failure.
is there known issues that would blow the transistor?? Similar to a fuse?? any shorts I should chase down??
thanks
thanks
are you sure the fan isn't working or is it just not allowing air to come through the vents ? check if one of the ac lines going through the chassis into the cabin is freezing up
neast70
09-26-2021 09:48 AM
khenshaw
04-28-2011 03:06 PM
