Datalogging not showing any "values" in lambda table with Crome Pro.
Old Jun 10, 2008 | 08:34 PM
RyanA's Avatar
Default Datalogging not showing any "values" in lambda table with Crome Pro.
OK, just hooked up to the ECU without the Ostrich and went out to datalog. The values on the right of the screen change fine and it's highlighting the cell that the logger is in. HOWEVER, it does not put any values in the cells at all; they just stay empty. Nothing is getting changed at all in any of the tables. What the heck am I doing wrong?
Ryan
Old Jun 15, 2008 | 02:40 PM
98vtec's Avatar
moderator emeritus
Default Re: Datalogging not showing any "values" in lambda table with Crome Pro. (RyanA)
you have to set the logging parameters in "tuner logging"
Old Jun 15, 2008 | 08:07 PM
RyanA's Avatar
Default Re: Datalogging not showing any "values" in lambda table with Crome Pro. (98vtec)
Actually figured it out. I forgot to disable the O2 sensor. If you leave it enabled it won't allow the chart to fill.
Old Jun 15, 2008 | 08:12 PM
98vtec's Avatar
moderator emeritus
well that was a de de de
Old Jun 15, 2008 | 09:01 PM
RyanA's Avatar
DE DE DEfinitely.....
Sir001
Engine Management and Tuning
Feb 12, 2017 07:21 AM
crxb16a90
Jan 5, 2010 07:24 AM
Btothe3rdDegree
Apr 15, 2004 07:23 PM
FragSyndrome
Apr 7, 2004 12:34 PM
89 CRX SI
Dec 7, 2002 06:25 AM
