Need a Map for b20.
Old May 17, 2008 | 08:31 AM
Hybridize's Avatar
Default Need a Map for b20.
Hey guys, I'm gonna be swapping a B20 in the next couple weeks, and I've just about have everything I need together.
Just bought a obd1 p75 ecu in the marketplace, that's running a turbo program using crome. I'll be staying NA, and lightly modded, so I'm gonna need some type of base map.
Would a stock P75 map work fine for I/H/E/mani/tb? Anyone able to supply me with a ROM?
Thanks,
Old May 22, 2008 | 06:40 PM
jry2598's Avatar
Default Re: Need a Map for b20. (Hybridize)
just take the chip out then u can just run the ls basemap...
Old May 23, 2008 | 09:46 AM
Relic1's Avatar
Default Re: Need a Map for b20. (jry2598)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jry2598 &raquo;</TD></TR><TR><TD CLASS="quote">just take the chip out then u can just run the ls basemap...</TD></TR></TABLE>
that would work great, all though the B18B map would run the B20 lean, and the ignition maps are not quite right... so I guess it wouldn't be good at all.
OP: there are B20 maps out there you can download. Check xenocron's site for some good basemaps.
Old Jun 4, 2008 | 01:50 PM
Bac91Da's Avatar
Default Re: Need a Map for b20. (Relic1)
Do you know anyone who has used Xenocron and did it work out for them???
Old Jun 4, 2008 | 02:00 PM
98vtec's Avatar
moderator emeritus
Default Re: Need a Map for b20. (Bac91Da)
if it was uploaded by xenocron, then i'm sure it would work as long as the motor is in the general playing field as yours.
all you need a basemap for is startup. Tune from the ground up and you'll never have problems with "basemaps"
Old Jun 4, 2008 | 06:25 PM
RC000E's Avatar
Default Re: Need a Map for b20. (98vtec)
I recently tuned a B20 hatch that ran an LS basemap. While his car didn't run too bad, his idle was ****. I retuned it and he hasn't had a problem since. I have a B20 bin if you can't find it. PM me if you can't find it anywhere.
Old Jun 4, 2008 | 07:15 PM
Bac91Da's Avatar
Default Re: Need a Map for b20. (RC000E)
my idle is fine i just have some backfire cause i have injectors that flow 10% more than stock and i have an adjustable fuel pressure regulator as bandaids for now so i am running a lil rich. But i would like to get the ecu chipped and tuned so i can get it running 100%
Old Jun 5, 2009 | 07:47 PM
curt5446's Avatar
Go here---> http://www.xenocron.com/bins/index.p...Crome/B-Series
Download the treyb20.bin
It's a stock B20 map that I just personally tried loaded onto my ostriche. I run a B20 OBD1 P75 with an LS trans. This finally got me through some mid range bog issues.
I'll try to keep you updated as I make this map my own.
JDMswagSerf
Feb 7, 2016 02:50 PM
efkilla
Aug 28, 2014 10:09 AM
ser13
Engine Management and Tuning
Oct 28, 2009 07:11 PM
ser13
May 29, 2009 05:31 PM
Jimmy
Jul 15, 2007 10:32 PM
