Hondata Bluebox
Old Jun 4, 2008 | 04:30 PM
dagle's Avatar
Default Hondata Bluebox
so i have the bluebox, this is the boost option right? and if it is, can this be used the same for S100's AND s200's? sorry for the noob question, just not familiar with this product. (i have a s300 now thats plug/play)
Old Jun 4, 2008 | 05:22 PM
TB123's Avatar
Default Re: Hondata Bluebox (dagle)
Are you talking about this blue box? - http://hondata.com/s200.html
If so, it is the s200 system.
Old Jun 4, 2008 | 06:04 PM
dagle's Avatar
Default Re: Hondata Bluebox (TB123)
only the s200 comes with a blue box? and yes i do believe it is that box, ill go outside and snap some pictures
Old Jun 5, 2008 | 02:15 PM
TB123's Avatar
Yeah, only the s200 comes with the blue box. The s100 and s300 systems fit inside of the ECU and do not use that interface box.
Old Jun 5, 2008 | 02:39 PM
b19coupe's Avatar
The blue box could either be an old school staged system or an S200. Either way, there is no guarantee that it is boost enabled. The boosted staged systems had a 'B' in the name on the box, for instance "2bn1208". The only way to tell if an S200 is boost enabled is to connect and datalog or to it or boost on it. If the check engine light comes on and it rev limits under boost, boost is not enabled.
Old Jun 7, 2008 | 02:22 PM
dagle's Avatar
Default Re: Hondata Bluebox (b19coupe)
i have 2bn1210, so this is a S200 boost?
Old Jun 7, 2008 | 09:26 PM
locash's Avatar
That sounds like an old Stage 2 with boost box, without datalogging. Unless is actually says S200 on it.. Either way, it's really old, and you might want to consider upgrading to the S300..
Chris1521
Mar 11, 2011 06:57 AM
TurboTeG4
Feb 11, 2008 08:53 PM
alltech_hybrid
Jul 16, 2005 11:59 PM
z1p
Oct 27, 2004 09:46 PM
boostincoupe
Jun 25, 2003 01:26 AM
