Need Help on P28 Circuit Board
Old Apr 6, 2008 | 09:00 AM
ken2830's Avatar
Default Need Help on P28 Circuit Board
Ok, one of my capacitor burnt up on the circuit board labled C21. does anyone know whats the function of that circuit? and if i could put a different size capacitor on there because it requires a 33 UF 35v but nobody has them, radioshack has 22uf 40 uf and other sizes but no 33UF, thanks...
Old Apr 6, 2008 | 10:16 AM
ken2830's Avatar
bump
Old Apr 6, 2008 | 05:17 PM
98vtec's Avatar
moderator emeritus
Default Re: (ken2830)
I couldnt tell you the function, but have you tried looking for the right capacitor on http://www.digikey.com ?
Old Apr 6, 2008 | 05:25 PM
b19coupe's Avatar
Default Re: Need Help on P28 Circuit Board (ken2830)
It is pretty common for the evap purge control circuitry in the P28 to fry itself.
Old Apr 7, 2008 | 06:42 AM
ken2830's Avatar
bummmppppp
Old Apr 7, 2008 | 07:13 AM
ken2830's Avatar
i need to know what is c21 in a p28 circuit board please.....that capacitor burnt and also if i could continue using my ecu with out it.....
Old Apr 8, 2008 | 07:10 AM
ken2830's Avatar
bummmp i need sum help on this.....
Old Apr 8, 2008 | 07:52 AM
98vtec's Avatar
moderator emeritus
no bumping, read the rules. If someone has an answer, they will post.
Old Apr 8, 2008 | 05:27 PM
mtber's Avatar
Default Re: Need Help on P28 Circuit Board (98vtec)
Replace the cap with the same exact cap & see if the ecu functions normally.
If it doesn't replace the ecu, easy as that :-)
Old Apr 9, 2008 | 08:37 AM
akandok's Avatar
Default Re: Need Help on P28 Circuit Board (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">Replace the cap with the same exact cap & see if the ecu functions normally.
If you read you will notice that he cant find the same capacitor.
OP, is there a reason as to why you are trying to revive the ECU?
Old Apr 9, 2008 | 08:38 AM
akandok's Avatar
But a quick search on google.com yields this result
http://www.futurlec.com/CapTant.shtml
$.20 a piece. Good luck with it
Old Apr 9, 2008 | 06:47 PM
ken2830's Avatar
thanks for the reply. but my main concern was that even though my car still runs good, idk if that circuit could mess sumthin up in the long run, but i heard that circuit is for the EVAP......
Old Apr 12, 2008 | 06:46 AM
civicjoe's Avatar
The Evap. Purge Sol. is controlled by Q31. It's common when converting from OBD2 to OBD1. If you plug the IAT sensor into the Evap. Purge plug then you will fry both the sensor and Q31 on the P28 board. How do I know? I did it less than 2 weeks ago.
Old Apr 12, 2008 | 09:56 PM
mtber's Avatar
Default Re: (civicjoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicjoe &raquo;</TD></TR><TR><TD CLASS="quote">The Evap. Purge Sol. is controlled by Q31. It's common when converting from OBD2 to OBD1. If you plug the IAT sensor into the Evap. Purge plug then you will fry both the sensor and Q31 on the P28 board. How do I know? I did it less than 2 weeks ago.</TD></TR></TABLE>
Just some FYI if you didn't already know. It will cook your IAT sensor also.
This issue is common when people do swaps, intake manifold upgrades etc. I see it all the time.
The obvious way to prevent this would be to label your plugs or memorize the wire colors to each sensor etc
Willie
Aug 25, 2005 01:34 PM
delsolrmp
Nov 30, 2003 09:42 PM
Hybrid
Nov 29, 2003 07:59 AM
