how to tune in an aggressive sounding 2 step
Old Apr 6, 2008 | 01:36 PM
tekturbo's Avatar
Default how to tune in an aggressive sounding 2 step
I was wondering how do you to in the those crazy shot gun sounding two steps like jeff evas and the other pioneers.
Old Apr 6, 2008 | 03:56 PM
hondaboy4life's Avatar
Default Re: how to tune in an aggressive sounding 2 step (tekturbo)
do you know how 2-steps work? cuz loud bangs are just the fuel being ignited in ur turbo and the louder the bang the more damage its doing. Most drag cars can afford it because they have the money and backup turbos.
I don't know that much about 2-steps either but i have had a lot of people tell me that 2-step isnt good for your turbo. Also making your 2-step sound louder just for the sake of sounding louder/ like gun shots seems kinda ricer to me.
Old Apr 6, 2008 | 04:23 PM
tekturbo's Avatar
wow thats interesting to know but how in the hell do you get the fuel to ignite in your turbo.
Old Apr 6, 2008 | 04:28 PM
mtber's Avatar
Default Re: (tekturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekturbo &raquo;</TD></TR><TR><TD CLASS="quote">wow thats interesting to know but how in the hell do you get the fuel to ignite in your turbo.</TD></TR></TABLE>
What you are referring to is an anti lag.
What engine management system do you have ?
Old Apr 6, 2008 | 04:57 PM
98vtec's Avatar
moderator emeritus
sounds like he is referring to the antilag setup.
1) you have to be turbo
antilag = retarding timing considerably and adding fuel.
I havent had the chance to mess with antilag yet, but it really helps for boosted motors at the track. This way they can launch with the motor in boost, which means less lag.
Old Apr 8, 2008 | 02:37 AM
tekturbo's Avatar
I am currently running crome,does crome even have an antilag.
Old Apr 8, 2008 | 06:22 AM
ive only used crome free but yes it does. For crome free its under pluggins and extra features. You can only use it on p30 and p72 code maps.
Old Apr 9, 2008 | 07:57 AM
Eddiebx's Avatar
if i remember correctly, the crome plug ins merely cut the fuel, so you are really only hitting a fuel cut, thats not going to give you fireballs out the exhaust that you are trying to acheive. u need to leave fuel and retard/cut ignition for that.
Old Apr 10, 2008 | 02:55 AM
tekturbo's Avatar
ok ill try that
Old Apr 10, 2008 | 08:02 AM
baller status's Avatar
Mine does that under WOT shifting. My tuner set it to only cut the ignition when at WOT and the clutch is in because he said he wants the fuel keeping the valves cool. But it's just a little pop. I'd prefer to have nothing at all, but if it serves a function, then I don't care.
One day you'll grow up and it will seem childish to want your car to mimic video games and movies.
Old Apr 10, 2008 | 09:28 PM
LoseRPunKx182's Avatar
Default Re: (baller status)
add some fuel & pull some timing..there's more to it but u can figure it out. i build full boost off my crome free antilag settings.
Old Apr 10, 2008 | 10:02 PM
Default Re: (LoseRPunKx182)
Don't just retard timing, CUT timing. With the AEM you can run a wire from the clutch and set it up so that at WOT, put the clutch in and it will cut the timing which drops RPMs so you don't have to let off the throttle. You have the option of cutting fuel or leaving it. If you leave it, unburnt fuel goes into the exhaust and ignites. Whether your software can do this I'm not sure. But WOT throttle shifting isn't just for turbos.
Old Apr 11, 2008 | 06:20 AM
yeah, crome free does fuel cuts...that's why its alittle customization with crome free.
Old Apr 11, 2008 | 10:49 PM
Cpt Ben's Avatar
When i had AEM standalone in my old boosted EK I ran ignition cut, and shot flames when I shifted. Launch control didnt shoot any flames though..just black smoke
Does Crome have ignition cut now as well as fuel cut for launch control?
Old Apr 13, 2008 | 04:17 PM
h22 civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baller status &raquo;</TD></TR><TR><TD CLASS="quote">Mine does that under WOT shifting. My tuner set it to only cut the ignition when at WOT and the clutch is in because he said he wants the fuel keeping the valves cool. But it's just a little pop. I'd prefer to have nothing at all, but if it serves a function, then I don't care.
One day you'll grow up and it will seem childish to want your car to mimic video games and movies. </TD></TR></TABLE>
i would imagine you are not able to preload the clutch setup like that?
Old Apr 13, 2008 | 10:58 PM
Default Re: (h22 civic)
I'm not sure what you mean by "preload".
On my car I had to run a wire to the clutch switch from an empty pin on the C harness. Some cars have a clutch input already at the ECU, but you would need to go to Options, Configure Outputs and set it up.
Old Apr 14, 2008 | 12:45 PM
h22 civic's Avatar
PRELOAD IS WHEN YOU RELEASE THE CLUTCH AT THE LINE JUST ENOUGH to put tension on the driveline so when you release it it doesnt shock the drive train wich save parts from breaking ,,now i imagine if you have the 2 step setup as you described you would not be able to preload the clutch or the 2 step would shut off?
Old Apr 18, 2008 | 11:31 AM
Jsarv's Avatar
you dont have to run the launch control to your clutch switch. you can run it to anything, defrost button, ac button whatever.
Old Apr 18, 2008 | 12:07 PM
Turbogixxer's Avatar
Default Re: (Jsarv)
2step like this?
http://www.youtube.com/watch?v=SQ3wBEY2e7g
integrawow
May 12, 2007 07:13 PM
Revlon Charly
Mar 15, 2007 01:29 PM
alekou
Welding / Fabrication
17
Oct 17, 2006 08:18 AM
ofl
Aug 11, 2004 05:19 AM
98silvercivicEX
Feb 15, 2004 12:27 PM
