Tuning with CROME?
Old Apr 9, 2008 | 10:00 PM
jvtec95's Avatar
Default Tuning with CROME?
Now that we have this nice section for ECU Tuning, could someone post a beginners 'how to tune' on CROME? I'm a DIY kind of guy and want to tuen my engine on CROME myself.
I think it'd be very helpful for everyone if someone with some tuning experience could run through how they street tune a car.
Thanks!
Old Apr 10, 2008 | 12:19 AM
98vtec's Avatar
moderator emeritus
Default Re: Tuning with CROME? (jvtec95)
http://www.xenocron.com/install/CromeGuide.htm
http://www.xenocron.com/instal...g.htm
http://www.moates.net/zips/cro...3.pdf
Modified by 98vtec at 3:26 AM 4/10/2008
Old Apr 11, 2008 | 09:11 AM
jvtec95's Avatar
Default Re: Tuning with CROME? (98vtec)
Great info! Thanks!
Would it be a good idea to make a sticky with this kind of info for the more popular management systems?
Old Apr 11, 2008 | 02:13 PM
baller status's Avatar
Only thing I would change about that write-up is to make it explicitly and undeniably clear what a base map is. It's not something you load up to your ecu and drive around with. It can be counted to get the car started and idling, or at least get you close enough that with some adjustments you can get the engine started.
I would not even trust loading one stock calibration onto another ECU. There are so many configuration options that aren't available in the software that I seriously doubt it gets transferred over. There is a lot more to a calibration than the fuel and ignition maps.
My interest in Crome and Uberdata was just that I wanted to view OEM calibrations. But then I realized that you can't see things like IACV frequency and motor rates, coil dwell, VTEC hysterisis points, etc etc etc.
juiced2ndgenteg
Engine Management and Tuning
Oct 27, 2012 10:25 AM
jdmfreak1992
Nov 20, 2008 08:23 PM
crvtkllr
Nov 15, 2007 06:12 PM
crohnman6
Jan 22, 2006 11:13 PM
TurboEF9
May 22, 2004 05:45 AM
