JDM H22a typical final timing
Old May 24, 2008 | 11:07 AM
BlackCRX's Avatar
Default JDM H22a typical final timing
Hi there, I was browsing thru the site and saw these 2 great dyno plots/tunes. I will be tuning my JDM H22a accord next weekend and I was wondering if you guys could give me some pointers.
http://forums.evans-tuning.com...26285
http://forums.evans-tuning.com...27562
I will have a wideband in the car, my plan will be to smooth out the afr and slowly add timing (1deg at a time), once I get to the point where I add timing and the afr does not change I will pull a couple of degress out (assuming this is where I will meet mbt). I was comparing some of the H22 basemaps on the web and they typically have approx 30-35* in high cam final column. I was wondering approx where my final timing should end up at, I will be running 94oct. I have heard that ppl typically don't go over 30* tho... can someone please give me some pointers/suggestions/advice.
Old May 24, 2008 | 12:09 PM
98vtec's Avatar
moderator emeritus
Default Re: JDM H22a typical final timing (BlackCRX)
add until it stops making power or you hear detonation.
Old May 24, 2008 | 02:10 PM
BlackCRX's Avatar
Default Re: JDM H22a typical final timing (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">add until it stops making power or you hear detonation.</TD></TR></TABLE>
i know that, but it is hard to tell when you only have a butt dyno
i cant afford real dyno time
Old May 27, 2008 | 03:07 PM
JDogg's Avatar
30 deg is good, you wont make anymore power w/more timing.
pcguy760
Jun 3, 2007 11:29 PM
bburtonsk8r2
Apr 20, 2006 05:32 PM
User 5426
Jan 14, 2004 02:36 PM
Timmayeg
Sep 25, 2002 08:55 PM
