I Have a B20 Vtec/B16 With a Sensor Problem? VTEC DOES NOT WORK?
Old Apr 18, 2008 | 04:01 PM
adolfovalen's Avatar
Default I Have a B20 Vtec/B16 With a Sensor Problem? VTEC DOES NOT WORK?
its a b20/b16vtec, stock internals, si tranny, with a type r intake manifold, and a 95 ex wiring harness,hondata s300. the intake temperature sensor is not connected(pluged into the intake), because the sensor does not mach the intake hole, will this disable the vtec from working? right now the vtec does not work but i can go high rpm 8000 with no problem but i dont feel the vtec kick,is it normal or i dont feel it kick because it got stock internals?
Old Apr 19, 2008 | 08:44 AM
D16Z6TURBO's Avatar
Do mechanics in your area a favor and try riding a pedal bike as it may suit you better
Old Apr 19, 2008 | 09:35 AM
Sr420Det's Avatar
No the vtec will not work if the ect sensor is not hooked up, make sure you dont have any sensors mixed up.
Old Apr 19, 2008 | 09:41 AM
D16Z6TURBO's Avatar
besides the fact that it is an important sensor in determining the amount of fuel needed so running without it is just stupid to begin with
Old Apr 19, 2008 | 01:42 PM
ok thanks so what do i do cut the d16 isensor and put a ls intake manifold sensor?
Laojoeturbo
34
Jun 24, 2009 08:47 AM
civicx
12
Aug 25, 2005 06:44 PM
Jmunk
Feb 22, 2005 02:53 AM
22civic
Jun 21, 2002 04:45 PM
