EFI University- Thumbs UP!
Old Jun 9, 2008 | 06:07 AM
VtecKiDD's Avatar
Default EFI University- Thumbs UP!
I know this topic has been posted before in the past but i thought alot of guys prob need to hear this again or for the first time.
I recently took a class at EFI University this past weekend. I went in with an open mind, but didnt really think i would learn alot from their beginner class.
I WAS WRONG.
Ive worked in this industry for 7 years. i have been around tuners and dynojets for the last 6.
I feel with their EFI 101 class i already know more than the "tuners" ive been around and that scares the crap out of me. It means all these cars ive seen tuned over the last few years, all the customers, power numbers, etc, i know more about the process of tuning than the people i was subbing TUNING out too.
I learned just how poorly educated i was.
It was the best money ive spent in this field, and i cant wait to take the advanced class next weekend.
The instructor was cool (Chris Marcelloro) , informative, we had group discussions and a demonstration.
If you think you know how to tune, or what tuning is, i challenge you to take even this beginner course because it will open alot of doors for you. It will teach you alot of valuable techniques.
FOr all you NOOBS coming up, take the class, its well worth it an it will make you a better tuner.
http://efi101.com/
Mike
Vteckidd
Old Jun 9, 2008 | 06:40 AM
98vtec's Avatar
moderator emeritus
Default Re: EFI University- Thumbs UP! (VtecKiDD)
i have been planning on taking the class once i get out of school.
anyone else taken the EFI 101 class? I read others opinions and they believe that buying ben's book was almost as good as the class. I have the book "electronic fuel injection" and have read it a few times and had always wondered about the actual class.
Old Jun 9, 2008 | 07:02 AM
VtecKiDD's Avatar
Default Re: EFI University- Thumbs UP! (98vtec)
I bought the book an read it before the class as well. It is NOT THE SAME THING.
THe book is a good introductory to the class, which is an introductory to tuning if that makes sense.
In the book they skim over things we spent hours talking about in the actual class. If you read the book it will help you understand the class better, but its def worth taking the class
Old Jun 9, 2008 | 07:12 AM
98vtec's Avatar
moderator emeritus
where did you take it?
Old Jun 9, 2008 | 10:16 AM
VtecKiDD's Avatar
right down the street from where i live, i got lucky LOL
Forged Performance in Marietta GA
Old Jun 9, 2008 | 01:34 PM
Turbo-charged's Avatar
every person on this forum will learn a lot in the EFI101 class. worth every penny
Old Jun 10, 2008 | 10:33 AM
VtecKiDD's Avatar
Default Re: EFI University- Thumbs UP! (Turbo-charged)
yeah im tying to take the Advanced class here soon. It was a great experience
Old Jun 10, 2008 | 08:25 PM
Riake's Avatar
I also took it at forged performance. Great class. Same instructor as well. I went in the middle of January. Highly recommended.
Old Jun 11, 2008 | 10:55 AM
alexsracing's Avatar
I got my efi-101
Old Jun 11, 2008 | 04:42 PM
nowtype's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">i have been planning on taking the class once i get out of school.
Ben's book is a hunk of dog ****. Jeff Hartman's book is thorough and easily puts you in a position to start tinkering after reading it. The end result is tuning is simple stupid guess and check work. The difficulty comes when the mechanics doesn't match up with the theory (ie, bad wiring, bad parts, parts installed correctly, electronics issues, ect.)
Old Jun 11, 2008 | 04:45 PM
98vtec's Avatar
moderator emeritus
Default Re: EFI University- Thumbs UP! (nowtype)
i liked jeff's book as well. It is a bit more indepth indeed. But that should not go to say that ben's book is not a hunk of crap.
Old Jun 12, 2008 | 08:49 AM
Furyof4's Avatar
Ive wanted to take this class for a while, as Id like to tune my own stuff with more confidence. I have Hartman's book and it is very informative from a tuning noob's viewpoint.
To bad the closest class is 8 hours away.
Old Jun 12, 2008 | 09:57 AM
Default Re: EFI University- Thumbs UP! (Furyof4)
dont worry...the class i took, after lay overs, was about 8 hours away on an airplane
Old Aug 6, 2008 | 09:07 AM
Unsivil_audio's Avatar
I'm so jealous right now, I've been wanting to take that class for years now. Just thought I'd post up too, the course outline this is the intro class and look at how much information it covers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">EFI-101 Outline
I. INTRODUCTION
1. About EFI University
II. ENGINE TUNING BASICS
1. The Four-Stroke Cylce
2. Engine Revs vs Engine Cycles
3. Volumetric Efficiency
4. What are Standard Conditions?
5. What are "Absolute" Conditions?
6. What is Air Density?
7. What is Air Flow (Volume vs Mass)?
8. KPA/BAR vs InHg/PSI
9. Brake Specific Fuel Consumption
10. Brake Specific Air Consumption
11. What is Air/Fuel Ratio?
12. What is Lambda?
III. BASICS OF ELECTRONICS
1. Voltage
2. Resistance
3. Amps
4. Vermont = Rhode Island
IV. WAVE FORMS
1. Sine Wave
2. Square Wave
1. Amplitude
2. Frequency
3. Pulse Width
4. Duty Cycle
3. Output Control
V. EFI SYSTEM COMPONENTS
1. Sensors
1. Map Sensor
2. Throttle Position Sensor
3. Coolant Temperature Sensor
4. Intake Air Temperature Sensor
5. Engine Speed
6. Camshaft Position Sensor
7. Knock Sensor
8. Oxygen Sensor
2. Actuators
1. Ignition Outputs
2. Fan Relays
3. Air Conditioning Relays
4. Injectors
5. Choosing an Injector
3. Control Tables
1. Base Fuel
2. Base Ignition
3. Boost Control
4. Idle Control
VI. HOW DOES IT ALL WORK?
1. PV = NrT
2. Calculating Injector Pulse Width
VII. TUNING THE ENGINE
1. What Air/Fuel Ratio Does My Engine Want?
2. Understanding Ignition Timing
3. Cold Starting
4. Fuel Requirements
5. Ignition Requirements
6. Dyno Tuning
7. Road Tuning
VIII. TOOLS OF THE TRADE
1. DVOM
2. Test Light
3. Powered Test Light
4. Vacuum Pump
5. Fuel Pressure Gauge
6. Oscilloscope
7. Dynomometer
8. Air/Fuel Ratio Monitor
IX. FUNDAMENTALS OF WIRING
1. Wire Sizes
2. Solder or Crimp?
3. Using Relays
4. Covering Wires
5. Crimping Tools
X. TUNING PROCESS: START TO FINISH
1. Fuel Type
2. Compression Ratio
3. Induction Type
4. Set Fuel Pressure
5. Getting Started and Running
6. Set Mechanical Base Timing
7. Tune engine to idle properly after Warm-up
8. Tune No-Load RPM sites
9. Tune No-Load acceleration enrichment
10. Tune light load RPM sites
11. Tune medium to heavy load RPM sites
12. Tune Full load RPM sites
13. Review Data Logs and Power Graphs
14. Make final changes
15. Street or Track tuning and testing
XI. FUN FORMULAS
1. Horsepower and Torque
2. Horsepower
4. Cubic Inch Displacements
5. Rev Limits
6. Fuel Injectors
Modified by Unsivil_audio at 11:12 AM 8/6/2008
Old Aug 8, 2008 | 08:24 AM
sanimalp's Avatar
$cat /dev/urandom
Man, thanks for this post.. i have been thinking of taking one of these classes for a long time, and i just checked the schedule as a result of this thread, and they will be doing a class about 10 miles away from me in a month.. bad ***.
Old Aug 8, 2008 | 08:39 AM
MadScientistMatt's Avatar
I took it in 2006 at Forged Performance, with the same instructor. What car did they have on the dyno this time?
Old Aug 8, 2008 | 08:56 AM
stewie8apie's Avatar
Default Re: EFI University- Thumbs UP! (MadScientistMatt)
Took this course a little over a year ago with the same instructor. Good class and great info. If nothing else it will just solidify your knowledge. You can't get the details that this class teaches from a book.
Old Aug 8, 2008 | 09:27 AM
SOHFAST94's Avatar
Here's to that. I'm certified. I do factory calibrations but I went just to see and I feel I left with a lot of gainful knowledge.
Old Aug 14, 2008 | 05:42 AM
zccr-xsi's Avatar
i heard that was a awsome school.im wanting to go really bad but the classes never come to fl.
Old Aug 14, 2008 | 12:11 PM
Sr420Det's Avatar
Hey vteckidd what did they teach you about VE?
Old Aug 14, 2008 | 01:57 PM
VtecKiDD's Avatar
Default Re: (Sr420Det)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sr420Det &raquo;</TD></TR><TR><TD CLASS="quote">Hey vteckidd what did they teach you about VE?</TD></TR></TABLE>
Alot, formulas, what it pertains to in terms of power, a/f ratios, etc.
I dont want to give alot away because it is someones business and i highly recommend you take the course.
PM me
Old Aug 14, 2008 | 03:37 PM
Sr420Det's Avatar
Just tell me this: Does a turbo increase VE?
Old Aug 15, 2008 | 06:23 PM
rorik's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecKiDD &raquo;</TD></TR><TR><TD CLASS="quote">I feel with their EFI 101 class i already know more than the "tuners" ive been around and that scares the crap out of me. It means all these cars ive seen tuned over the last few years, all the customers, power numbers, etc, i know more about the process of tuning than the people i was subbing TUNING out too.
Mike
Vteckidd</TD></TR></TABLE>
I've heard people say this same thing before, but without a specific in depth example of something learned, how do you sell it?
an analogy would be how are you going to buy a cd if you haven't heard any of the songs?
Give us a sample..
Old Aug 15, 2008 | 11:06 PM
baller status's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nowtype &raquo;</TD></TR><TR><TD CLASS="quote">
Ben's book is a hunk of dog ****. Jeff Hartman's book is thorough and easily puts you in a position to start tinkering after reading it. The end result is tuning is simple stupid guess and check work. The difficulty comes when the mechanics doesn't match up with the theory (ie, bad wiring, bad parts, parts installed correctly, electronics issues, ect.)</TD></TR></TABLE>
As much as I like Jeff Hartman's book, I would call you a fool if you said that you were able to tune anything after having read it. Lots of good basic info but not a whole lot that you can actually apply when you sit down on the dyno with a laptop.
What I would like to know is whether you feel that after taking this class, a person with no real experience could sit down with a laptop on the dyno and tune a vehicle.
I plan to take the class. When I asked a guy at the shop where my car was tuned what he thought of the class he said basically that it was interesting but he didn't learn anything applicable that he didn't already know; that he would recommend you save your money and just buy the book if you already have dyno experience. But I still want to take it.
I remember on the AEM forum when Ben first starting talking about offering the class. It's pretty cool how far his idea has come since then.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sr420Det &raquo;</TD></TR><TR><TD CLASS="quote">Just tell me this: Does a turbo increase VE?</TD></TR></TABLE>
Having spent some time reading through archives and keeping up with efi101's forum, I can tell you that Ben would answer your question "no". But that's just another opinion with many credible contradicting opinions.
Modified by baller status at 12:15 AM 8/16/2008
Old Aug 16, 2008 | 05:28 AM
VtecKiDD's Avatar
Default Re: EFI University- Thumbs UP! (rorik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rorik &raquo;</TD></TR><TR><TD CLASS="quote">
Give us a sample..</TD></TR></TABLE>
You learn so much of the WHY and the HOW.
Most of the tuners ive worked with dont REALLY understand anything about VE or Cylinder Pressure or even how TIMING works. Which is kinda scary lol.
WIth the proliferation of cheap or free tuning software it seems EVERYONE thinks they are a tuner. Punch some numbers until you get the right a/f ratio and you gods gift to the dyno.
Its simply not that easy.
