chip problem
Old Apr 8, 2008 | 03:05 PM
allmotor2.1's Avatar
Default chip problem
Have s200 with p28ecu after the tune is burn on chip and pluged into the car it wont start. Tried a b16 ecu and the car started. The p28 works because it came out of a running car. Is it that the the hondata is not reading the chip or should i just up grade to s300. Please Help
Old Apr 8, 2008 | 05:22 PM
98vtec's Avatar
moderator emeritus
Default Re: chip problem (allmotor2.1)
what was the process of burning the chip and what was used to burn it?
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotor2.1 &raquo;</TD></TR><TR><TD CLASS="quote">Have s200 with p28ecu after the tune is burn on chip and pluged into the car it wont start. Tried a b16 ecu and the car started. The p28 works because it came out of a running car. Is it that the the hondata is not reading the chip or should i just up grade to s300. Please Help </TD></TR></TABLE>
Take the ecu & the hondata to a local hondata tuner/dealer & have them diagnose it for you.
Old Apr 9, 2008 | 04:59 PM
zccr-xsi's Avatar
Default Re: chip problem (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">
Take the ecu & the hondata to a local hondata tuner/dealer & have them diagnose it for you. </TD></TR></TABLE>
if u dont do that and u screw it up hondata will wont give u your money back.
Old Apr 9, 2008 | 09:16 PM
mtber's Avatar
Default Re: chip problem (zccr-xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">
if u dont do that and u screw it up hondata will wont give u your money back.</TD></TR></TABLE>
Hondata doesn't give you your money back for anything, they will warranty items.
Old Apr 10, 2008 | 05:19 AM
zccr-xsi's Avatar
u might have something wrong within the bin itself.and when u say its not starting does it throw a soild cel?
rippinitup01
Jan 21, 2008 09:52 AM
redlseg
May 20, 2005 11:36 AM
JFG Kevin
Oct 26, 2004 04:11 AM
baonest1
Mar 5, 2003 09:11 PM
