oscillating fuel delivery?
Old Apr 7, 2008 | 06:39 AM
93preludes's Avatar
Default oscillating fuel delivery?
I've got an h22 on crome that recently started giving me an odd oscillating sound whenever it's at idle. This is not a vaccum leak like most of you would probably think because the RPM does not change but the engine's tone changes, it seems to go up and down but the motor and a/f is steady.
Trying to bounce some ideas off you all because i'm stumped...
Old Apr 7, 2008 | 10:11 AM
98vtec's Avatar
moderator emeritus
Default Re: oscillating fuel delivery? (93preludes)
do you have a wideband? sounds like its running lean.
Old Apr 7, 2008 | 07:01 PM
arc_55's Avatar
An oscillation can be felt by the slowing of the crankshaft due to the inefficiency of a combustion event or misfire. Some setups will misfire earlier then others in terms of AFR, but it depends on your setup. Some engines don't like to run as lean at idle... what is our idle AFR and specs on your setup?
Old Apr 8, 2008 | 05:14 AM
93preludes's Avatar
Default Re: oscillating fuel delivery? (98vtec)
yeah, wideband reads "normal" for my car, 14-15 at idle... i've never had this problem before and it has become more prevalent as of late. I am going to try to richen the mixture and see if that helps.
Old Apr 9, 2008 | 04:46 AM
93preludes's Avatar
I looked at it last night and the behavior is the same... i did drive around to check for it before making any changes and it does appear to lean out a bit when it starts behaving that way.
I'm not sure what could be causing this... could a bad o2 sensor be the issue?
MalcolmV8
Engine Management and Tuning
Mar 19, 2012 06:02 PM
ncsi
Feb 9, 2012 02:06 PM
ncsi
Jan 3, 2012 03:08 PM
welfarepc
Sep 13, 2007 05:15 PM
Hyaboosta
Jul 13, 2005 02:14 PM
