Are Wiring Harnesses interchangable
Old Apr 8, 2008 | 09:57 PM
dwarfsinhondas's Avatar
Default Are Wiring Harnesses interchangable
I'm swaping from a b16a2 engine obd2 in my '99 civic to a b18c1 obd2 and was wondering if the ECU could plug right into the existing wiring?
Sorry I guess I could move this question to the swap forum if this isn't the right place.
Old Apr 8, 2008 | 10:41 PM
MADMAX_zero's Avatar
Default Re: Are Wiring Harnesses interchangable (dwarfsinhondas)
What year is the Integra ECU?
If 00-01, then yes, otherwise no.
I would just ditch the OBD2 teg ecu, get a chipped VTEC OBD1 ecu, an OBD2B-OBD1 ecu jumper harness, bolt on some crap like I/H/E, and get it tuned.
Old Apr 14, 2008 | 04:50 PM
White Smoke's Avatar
i my honda
Global Mod
Your harness is OBD2 B so you would need an OBD2B connector plug on your ECU. As MADMAX_zero, that would be from an 00-01 Integra. They do also have OBD2B to OBD2A conversion harness's to use the 96-99 integra ECU.
Scott Little
Feb 3, 2020 06:18 PM
motiis
Jun 8, 2013 08:07 PM
jdmchickx
10
Oct 26, 2011 06:03 PM
killacam661
21
Aug 7, 2007 07:45 AM
sshaikh01
Mar 22, 2003 07:10 AM
