s300 fuel cut problem.....
Old May 2, 2008 | 11:21 AM
0930_SI's Avatar
Default s300 fuel cut problem.....
i loaded up a basemap for a p28 and adjusted my injectors to 550. my rpms are limited to 4000 with the car parked, and under load, the fuel cuts out at 2000 rpm constantly. i am just trying to get it driveable to get it to the shop to get tuned without having to tow it...
am running:
lsvtec turbo 60-1
gsr cams
built block...etc.
anyone know what the problem is?
Old May 2, 2008 | 02:19 PM
0930_SI's Avatar
Default Re: s300 fuel cut problem..... (0930_SI)
anyone?
Old May 2, 2008 | 05:02 PM
calvinPGMFI's Avatar
Do you have any error codes?
Old May 2, 2008 | 05:44 PM
0930_SI's Avatar
none....
Old May 2, 2008 | 05:54 PM
then it should be normal.
There is a change that your s300 is not communicating with the ecu. i would seek support on hondata forum
Old May 2, 2008 | 11:58 PM
0930_SI's Avatar
Default Re: (calvinPGMFI)
anyone else?
Old May 3, 2008 | 07:47 AM
IN VTEC's Avatar
It could be a lean misfire or a rev limiter that's set too low.
Old May 3, 2008 | 06:15 PM
0930_SI's Avatar
Default Re: s300 fuel cut problem..... (IN VTEC)
figured it out...... car is running like a champ now... it was a TPS wire prob. thanks though
chewyv
Engine Management and Tuning
Jun 14, 2015 05:58 PM
310tpi
12
May 7, 2007 08:45 PM
redcivicek
Jan 12, 2004 09:39 AM
vtec.dc2
Sep 30, 2003 08:49 PM
WykidEH
Mar 18, 2002 01:02 AM
