Throttle cable loose?
Old Apr 26, 2008 | 09:56 AM
lovelife6431's Avatar
Default Throttle cable loose?
Would the tuner be able to tell if it was getting wide open throttle?
Would his laptop show this?
The reason I ask is because when I left the throttle cable was loose and fell off!
Tuning hondata s100 on a dynapack dyno.
Old Apr 26, 2008 | 11:07 AM
98vtec's Avatar
moderator emeritus
Default Re: Throttle cable loose? (lovelife6431)
yes.
yes.
that graph is pretty weak in the middle. what is your setup?
Old Apr 26, 2008 | 11:47 AM
Default Re: Throttle cable loose? (98vtec)
Thanks for responding
setup:
jdm sir-g
skunk2 IM
Blox b cams
blox dual springs
4-1 header
2.5 in. exhaust
no cat
2-layer hg
short intake
new valve job and .005 resurface
-Also it pulls way harder now that I fixed it. wonder if I should re-tune
Old Apr 26, 2008 | 12:07 PM
Also here is my dyno from when I only had I/H/E on a dyno known to make 3whp more than the one I just did:
Old Apr 26, 2008 | 12:12 PM
98vtec's Avatar
moderator emeritus
https://honda-tech.com/zerothread?id=2285023
Old Apr 26, 2008 | 12:15 PM
I know but still why's the new one look so weak?
Old Apr 26, 2008 | 12:25 PM
98vtec's Avatar
moderator emeritus
its only weak from 5 to ~6200. as that range is not large, it just happens to be in the most critical area of the map as that is where you likely land between gears.
to me it looks like the vtec engagement needs to be higher. But bisi had to have taken that into consideration, i dunno. Thats something you need to ask him.
Old Apr 26, 2008 | 12:30 PM
Thanks I'll be calling him on monday when he's open again
Old Apr 26, 2008 | 03:58 PM
2fast4u831's Avatar
I'm really 2slow
did you ever dyno with stock cams?
Old Apr 26, 2008 | 06:22 PM
98vtec's Avatar
moderator emeritus
Default Re: Throttle cable loose? (2fast4u831)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fast4u831 &raquo;</TD></TR><TR><TD CLASS="quote">did you ever dyno with stock cams? </TD></TR></TABLE>
thats what the 2nd gear is tard
Old Apr 27, 2008 | 09:26 AM
2fast4u831's Avatar
I'm really 2slow
ahh ****. haha!! I think cams are too big for that little beast.
Old Apr 28, 2008 | 04:14 PM
Suprdave's Avatar
Wow, you guys are quick to start pointing fingers.
Dynapack Dynocharts show up weird, compared to dynojet....hard to read and they always look horrible. Theres a mode he can switch to that makes it looks like a Dynojet. Go back, get a printout and then you can really see if there is a vtec-dip. Bisi has been in the game for long enough, that I'm pretty confident he didn't screwup the vtec cross-over on such a simple setup. Get that new printout, and report back.
EgK2o09
Dec 30, 2010 11:34 PM
fastprpapi
May 3, 2008 10:09 PM
vinuneuro
Feb 26, 2006 10:14 PM
