What are the limits for the stock ECU?
Old Apr 7, 2008 | 12:47 PM
dwarfsinhondas's Avatar
Default What are the limits for the stock ECU?
What can the stock ECU handle ?
For people wanting to make positive changes but retain stock ECU for one reason or another.
In my case I would like to put a b18c1 shortblock on by b16a2 head and retain my ECU. If I use a JDM shortblock my compression will remain close to stock, but will the ECU be able to compensate for the added displacement with out throwing any CEL?
I would only need to run it in this condition for testing purposes and then I could conceivably use a chipped ECU and make other changes such as cam gears/shafts. Just need to know if this setup could work before I go ahead and put it together.
Any help is appreciated...
Thanks
Old Apr 7, 2008 | 01:15 PM
mtber's Avatar
Default Re: What are the limits for the stock ECU? (dwarfsinhondas)
What factory ecu are you running ?
The factory ecu doesn't "learn" or "adapt" to any changes besides knock & open/closed loop conditions, engine coolant & intake air temperature changes etc.
This is why tuning using an obd1 ecu & obd2 to obd1 jumper harness is necessary.
Old Apr 7, 2008 | 05:27 PM
98vtec's Avatar
moderator emeritus
if you use a p30 ecu, you will be fine. Everything that the ecu bases its fueling/ignition on is on the head unless you have a crank sensor located on the oil pump.
Old Apr 7, 2008 | 06:47 PM
arc_55's Avatar
I am sure it will be driveable, but it would probably be as effective to the extent of a basemap. I would highly recomend going to obd1 if u aren't already and have the car at a minimum street tuned. Tuning really puts the peices together on every setup so its something that shouldn't be overlooked.
Old Apr 7, 2008 | 06:54 PM
98vtec's Avatar
moderator emeritus
Default Re: What are the limits for the stock ECU? (arc_55)
stock b16 head, stock b16 ecu. stock block. Shouldnt run the car much different.
i am running a stock p13 on my 12:1 89x95 h23vtec and it runs it well enough to drive.
Old Apr 7, 2008 | 07:02 PM
Default Re: What are the limits for the stock ECU? (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">What factory ecu are you running ?
My ECU is the P2T.
So I'm guessing I would be running lean with stock ECU and the added displacement and that may cause me to throw a CEL and possibly mess my engine up?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">if you use a p30 ecu, you will be fine. Everything that the ecu bases its fueling/ignition on is on the head unless you have a crank sensor located on the oil pump.</TD></TR></TABLE>
Which engines have the crank sensor?
Old Apr 7, 2008 | 11:47 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwarfsinhondas &raquo;</TD></TR><TR><TD CLASS="quote">
My ECU is the P2T.
I doubt you will mess your engine up, however the p2t ecu looks for more sensors then you really need. Get your self an obd2 to obd1 jumper harness & a chipped obd1 ecu & be happy
The obd2 version of the p30 which is a p2t from 99-00 civic si b16a2 motors uses a crank sensor located on the oil pump.
fuzzysig
Engine Management and Tuning
Jun 12, 2017 05:48 PM
jdmborn
Jun 20, 2009 08:15 AM
kanSiR
Nov 8, 2007 08:02 AM
mrx
Mar 28, 2005 05:56 AM
95excoupe
Feb 25, 2005 05:25 PM
