getting the car started
Old May 20, 2008 | 10:31 PM
cast98integra's Avatar
Default getting the car started
i just started my car two days ago, it's an 98 integra with b18b(stock block) turbo and ITB's . the car start and everything but i have a very rought idle reading 10p/m on the boost gauge, the car seems to be running soo rich, it's puffing black smoke and backfires. the tips of the plugs are Very greasy ( they were new plugs 5minutes before i turned the key) i did a very short road test and the car won't go over 4000rpm. i can't read the CEL code by jumping the connector of the green rubber plug. Must be problem with sensors or defect ecu ( ecu was made to work with my 450cc and crome boost basemaps). Any suggestion to resolve the problem before dynoday??
Old May 21, 2008 | 11:33 AM
calvinPGMFI's Avatar
This needs extreem tuning..
-TPS indexing with boostcompensation.
-TPS indexing for load <1024mbar and MAP indexing for load >1024mbar
Only 3 systems will allow you to do this.
eCtune, Neptune, s300(i believe never used it)
But eCtune and Neptune can do it for sure.
Old May 21, 2008 | 11:34 AM
if you can't rev more then 4000rpm and can't pull cell(mil) codes means your ecu is limp mode.
Wrong chip installed, bad soldering, etc etc
Old May 21, 2008 | 02:41 PM
b19coupe's Avatar
Default Re: getting the car started (cast98integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cast98integra &raquo;</TD></TR><TR><TD CLASS="quote">i just started my car two days ago, it's an 98 integra with b18b(stock block) <U>turbo and ITB's</U> . </TD></TR></TABLE>
Sounds like a pretty unique setup. Do have any pics?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by calvinPGMFI &raquo;</TD></TR><TR><TD CLASS="quote">if you can't rev more then 4000rpm and can't pull cell(mil) codes means your ecu is limp mode.
Wrong chip installed, bad soldering, etc etc</TD></TR></TABLE>
And what he said
Charlie Moua
Sep 29, 2014 04:37 AM
HeedLessInc
Dec 27, 2006 10:25 PM
b16ahybrid
Feb 13, 2006 02:44 PM
integrx
May 18, 2004 08:45 PM
