ECU with no VSS
Old May 25, 2013 | 06:34 PM
daigo's Avatar
Default ECU with no VSS
Looking for some experienced information. I have an application that does not have a VSS, and no provision for adding one. Does anyone know through experience whether Hondata or Neptune can operate effectively without one or do you have to go with and aftermarket ECU such as AEM.
Yes, I've tried the search.
Thanks
Old May 25, 2013 | 06:37 PM
JDMAF's Avatar
Default Re: ECU with no VSS
Trigger wheel setup possibly???
Old Jun 10, 2013 | 10:54 AM
VegasInvasion's Avatar
I'm Huge In Japan
nothing runs a honda better than a honda ecu. you can disable the VSS, and disable the Vtec speed check, it should run fine. but you can not use launch control or FTS unless you trigger it using a clutch switch or some type of input signal.
apoptosis
Jan 22, 2008 02:49 PM
HotWheelz
Dec 23, 2003 10:14 PM
ROCcityRSX_S
Nov 26, 2002 06:22 AM
