chipped ecu problems?
Old May 28, 2013 | 11:21 AM
stomple's Avatar
Default chipped ecu problems?
i have a 1990 integra with b18a1 and 5 speed swap just intake and exhuast done to motor for now,when i run what i believe is a auto ecu it runs perfect with no problems or codes,however if i run a chipped pr4 obd0 5spd ecu it starts runs and drive but if i touch the brake pedal it dies but is still not throwing any codes or anything and starts right back up...could this be a ecu problem or maybe my alarm???? at a total loss
Old May 28, 2013 | 11:26 AM
JuggerNaut-CTR's Avatar
Default Re: chipped ecu problems?
If it runs fine with the other ecu, then I would assume the new ecu would be the suspect
Old May 29, 2013 | 05:42 PM
swordofdoom's Avatar
I suggest you check the soldering and look for any bad solder.
§95HATCH§
May 16, 2009 07:19 PM
vtec_lude
Dec 13, 2006 07:25 PM
B2AMMO
Nov 24, 2003 04:11 AM
b16aeg
Jul 24, 2002 04:45 AM
