chipped P28 bad?
Old May 25, 2013 | 06:58 PM
ceearexx's Avatar
Default chipped P28 bad?
I have a chipped p28 ecu that keeps throwing code 8 for tdc sensor i tried a diffrent ecu and it stops.
Anyone know why? maybe a bad solder in the ecu?
Old May 26, 2013 | 02:31 AM
swordofdoom's Avatar
Default Re: chipped P28 bad?
Open up the ECU and check to see if there are any burnt circuit traces. More than likely something is fried.
Old Jun 10, 2013 | 11:09 AM
VegasInvasion's Avatar
I'm Huge In Japan
you won't be able to find any burned traces strictly for the TDC circuit, it's in the hybrid boards. if it is in fact the ECU then you probably popped a tiny capacitor that you can't identify visually, and it takes a lot of skill to replace that board.
But 99% of the time it's the distributor or wiring causing the problem, so troubleshoot elsewhere first. pull the dizzy plugs, check the pins, look for exposed wiring, loose connections, jumper harness if you have one.
JeffBro
Engine Management and Tuning
11
Jan 5, 2011 04:20 AM
blackcivic11
17
Jul 24, 2009 01:32 PM
spoonhatchblack
Nov 4, 2004 10:12 AM
