Help getting me going...
Old May 16, 2013 | 09:59 PM
JDMAF's Avatar
Default Help getting me going...
ok setup is
96spec b18c type R
IHE
Just got S300 have a lc-1 hooked up... Car has Walbro 255lph fuel pump and adj fpr.
I load up the stock ITR map try to start the car and nothing... get it started with a bit of right foot and have to hold it there to keep it going... shows 10.5 on the AFR guage and that I need to pull 98% fuel all over the place... obviously not driving just trying to get it to idle at this point... Base fuel pressure is set at 45psi.
question is...
Since it has a much stronger fuel pump does the "normal" stock fuel pressure of 45-50 need to be turned down due to the pump pushing harder??? or am I thinking about this wrong???
Also is throwing code 14 over and over... iacv... this code does not throw when stock computer is in car...
Thanks for any help.
Old May 17, 2013 | 04:48 AM
scmil95eg's Avatar
Default Re: Help getting me going...
No, you're just bypassing more.
Yep.
Old May 17, 2013 | 12:29 PM
JDMAF's Avatar
ok so I can get the car to idle once it is warmed up so im assuming that I need to go in and take out the enrichment start up fuel... I got it to idle at 14.7... do I just need to just blanket the whole table and bring it down???
ejfromwestbay
Aug 18, 2010 05:44 PM
rbizzell30
May 9, 2009 04:27 AM
b16hatche
Nov 11, 2005 06:28 PM
slow02ss camaro
Jan 31, 2003 06:45 AM
Boostless97Lude
Dec 26, 2002 06:55 PM
