Changed dizzy, cant set base timing to 16
Old Jun 18, 2013 | 07:39 PM
lindseyhunt1090's Avatar
Default Changed dizzy, cant set base timing to 16
hey everyone. I ran into a problem. I had a leaking distributor so i changed it and now i cant set my base timing.
Im running a boosted lsvtec (600+hp) car was running fine but my dizzy was leaking oil and i also bought a block off plate for the plug wire cap because im running hondata cpr (coil on plug retro fit) and it didnt fit with the old dizzy. the cap fit the new dizzy so i put it on. both are vtec dizzys and bolt to head fine. with the new one on i went into my hondata to the set timing tab to try and lock it at 16 degreese. with the dizzy all the way advanced i can only get the timing light to show 14 degreese where the old dizzy showed 16 degreese with it in the center position. whats up with that? now i dont know what the heck to do and fear of poping the motor lol. i also have to be at map proving ground in 2 days lol help.
Old Jun 19, 2013 | 03:50 AM
LightningTeg's Avatar
Community Builder
Default Re: Changed dizzy, cant set base timing to 16
What happens when you rotate the distributor when the timing is locked on the computer?
Old Jun 19, 2013 | 05:20 AM
I have not tried this. ill try soon as I get home. what will this tell me
Old Jun 20, 2013 | 08:30 AM
2000CTRSi's Avatar
I have had this issue when using a non original Honda distributor. The remanufactured ones will not sync.
Old Jun 22, 2013 | 05:30 AM
Muckman's Avatar
Moderator in Chief
Lindsey, what's your intake cam gear set to?
crappyshifting
Jul 18, 2013 09:00 PM
FlewByU352
Nov 13, 2010 07:27 PM
srv3fender
10
Jul 24, 2005 11:25 AM
