ECU/Engine Trouble! Help!
Old Mar 22, 2013 | 05:13 PM
CKnight90's Avatar
Default ECU/Engine Trouble! Help!
My engine was flooding so I figured it maybe was Grounded wire or Injector...
I had injectors serviced.
Checked for grounded wire.
Put serviced injectors in today..
Engine still floods.
Found out 1 wire on my ecu is unplugged. From the ecu to the plastic connector.
Could this cause the problem? Here's a short video..
http://www.youtube.com/watch?v=Xakli...ature=youtu.be
I also talked to a guy at a Auto Sports shop who said, "Grounded wire, injectors, or Bad tune" How could it be a bad tune when I didn't even mess with the tune?
Old Mar 23, 2013 | 03:48 AM
7rrivera7's Avatar
Default Re: ECU/Engine Trouble! Help!
Looks pretty obvious to me that you found the problem...
Old Mar 23, 2013 | 09:41 AM
CKnight90's Avatar
But would this cause the engine to flood?
Old Mar 23, 2013 | 10:34 AM
7rrivera7's Avatar
Can't tell from the video where the wire is supposed to go but if you show me with a pic or another video, I'll tell you what the missing pin should control.
Old Mar 23, 2013 | 03:28 PM
CKnight90's Avatar
Icon3 Re: ECU/Engine Trouble! Help!
Hope this helps!
Old Mar 23, 2013 | 04:37 PM
7rrivera7's Avatar
No dice - let's do this. take a picture of where the loose green is coming out of the other end on the ECU side and I'll match it on one of my harnesses.
Old Mar 24, 2013 | 10:08 PM
CKnight90's Avatar
found where it goes, got it connected. Still Engine flooding. Probably just let the shop figure it out. Thx though!
Old Mar 28, 2013 | 09:22 PM
CKnight90's Avatar
Alright. I took it to the shop. I was told my ECU is not a Hondata S300(which I was told when purchased..bummer!). I guess its a chipped ecu. He said he thinks the ecu chip went bad and its making the injectors send more fuel then needed? I guess I'll have to explain more detail here to try to figure it out..because I don't think it's the ECU(just my opinion).
My car over heated. Was wondering why because when I bought it and drove it back to my town(1hr away), it never over heated. So I find out the radiator had a leak. I refilled the system. Went online ordered a new radiator. Along with a exhaust manifold gasket, because cyl 4 gasket was leaking. I wake up one morning, go start my car, hard start. Look under the hood. Notice something wet kinda drippin out of the bad gasket area on the exhaust manifold. Didn't think much of it(Shouldn't of). Filled up the coolant again. Drove on. The next day it was spraying instead of dripping. Not leaking...Spraying!
I want to know if the ecu went bad, wouldn't it make the injectors spray instead of drip the first time?
Or did the overheat make the head warp/crack? which would cause it to flood in the engine?
It runs, Idles, just sprays.
Thoughts please! THANKS!
19t EX coupe
Nov 6, 2005 09:31 AM
jtracing919
Jan 11, 2005 06:45 AM
HamiltonRex
Jul 10, 2004 01:05 PM
