obd1 pinout shocktower
Old 06-03-2013, 11:44 PM
kpjo4's Avatar
Default obd1 pinout shocktower
By any chance does anyone have the obd1 pinouts for the 3 shock tower ecu harness plugs on the passenger side? I've been searching for awhile and only seem to stumble on the ecu pinouts.
Old 06-09-2013, 02:00 AM
TinyD2point0's Avatar
Default Re: obd1 pinout shocktower
im having the same problem. but i need the engine harness side. what ecu are you running...
Old 06-16-2013, 09:55 PM
dr.rez1989's Avatar
my ecu was stolen out of my car along with the plugs so a bunch of loose wires where the ecu used to be. i used a multimeter to perform a continuity test for each wire that led to the engine bay, this is what i came up with using a ecu harness i took out of a automatic civic(eg) ex:
Plug 1=14 pin (from left to right)
top row: A16=alternator control(white/yellow) A6-=primary o2 sensor heater control(orange/black) A4=vtec solenoid(orange/white)
2nd row: D21=sensor ground 1(green/blue) D17=MAP sensor(pink/white) D19=sensor voltage for MAP D6=vtec pressure switch(orange/blue)
3rd row: D11=throttle position sensor(pink/black) D22=sensor ground 2(green/white) D20=sensor voltage for TPS(yellow/white) A21=ignition control module(red/green)
bottom row: D15=intake air temp(red/yellow) D13=engine coolant temp sensor(red/white) D9=alternator FR charge signal(pink)
Plug 2-10pin
top row: B2=logic ground 2(brown/black) D14=primary heated o2(white) A26=logic ground 1(black/red)
middle row: B11=CYP sensor p-side(orange) B12=CYP ground m-side(white) B13=TDC ground p-side(orange/blue) B14=TDC ground m-side(white/blue)
bottom row: B15=CKP P ground(blue/greemn) B16=CKP M ground(blue/yellow) empty
Plug 3-4pin
Top: A3=injector 2(red) A1=injector 1(brown)
bottom: A2=injector 4(yellow) A5=injector 3(light blue)
sorry for the shitty pics
Old 06-16-2013, 09:56 PM
dr.rez1989's Avatar
i used this write up as a reference, although not all the colors matched
http://technet.ff-squad.com/wiring.obd1.htm
Old 03-04-2014, 10:17 PM
Mark Hopper's Avatar
I know this is an old post, I'm wireing in a obd1 z6 in to an obd2a car, which pin and plug on the engine harness is the right one for the iacv, don't see it listed on here?
Cheers
josh_db1
05-11-2010 08:35 AM
jamesfawcett
04-12-2010 08:44 AM
dusterbd13
09-19-2009 09:32 PM
hbhonda
10-20-2006 06:33 PM
mugenwannabe
11-17-2003 11:23 AM
Quick Reply: obd1 pinout shocktower
