4 channel pyrometer controller
Old Mar 28, 2013 | 10:26 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default 4 channel pyrometer controller
anyone has any suggestions to a nice 4 channel EGT controller? what methods of attaching the probes to the turbo manifold (cast) runners do you suggest? can a clamp style be used in a high pressure and heat environment?
Old Mar 29, 2013 | 09:18 AM
accorse07's Avatar
Default Re: 4 channel pyrometer controller
How bout an AEM 4-Channel K-Type Thermocouple Amplifier? As long as you have something that accepts an analog signal for logging; The sensors are much cheaper than RTD style sensors and have a larger heat range.
Not sure on mounting style but I do not think clamp style would be recommended or even available(on the k-type thermocouple).
Old Mar 29, 2013 | 10:01 AM
i looked at that and the TC-4 by Innovative, the main issue is lack of monitoring. i am used watching EGTs on a display on the instrument panel on an aircraft and would like the same.
this is what i found so far
http://thesensorconnection.com/gauge...obe-kit-gas-ra
this is the sort of clamps we use on the lycoming engines
http://thesensorconnection.com/egt-p...mp_probe.shtml
Old Mar 29, 2013 | 10:42 AM
accorse07's Avatar
Nice looking kit there. If you are used to viewing your EGT's on a HUD than that one looks like a sound choice. The only draw back would be logging the info for tuning purposes.
As for the mounting clamps, AEM uses something similar for O2 sensors. I don't see any drawback to having it mounted in that manner. It's just aesthetic look and possible error of installation that i shy away from that approach. Welding on bungs would be clean and there is peace of mind not worrying about a clamp vibrating loose.
Old Mar 29, 2013 | 11:58 AM
can those bungs be welded onto a cast manifold? will an AEM or the TC-4 unit be able to transmit and display the data on a TunerView, for example?
Old Apr 1, 2013 | 08:27 AM
accorse07's Avatar
Yes they can be welded to cast manifolds. As for the Tunerview, so long as it has inputs for either serial connection or 0-5Vanalog connection, the data should be transferable and viewable
Old Apr 1, 2013 | 10:37 AM
HRTuning's Avatar
If it can output 0-5v references to the EMS then the TunerView can use that information.
Old Apr 1, 2013 | 10:59 AM
thank you, as we discussed elsewhere, i'll just make my own amp.
Old Apr 3, 2013 | 11:18 AM
xenocron's Avatar
AEM now sells them with amp built in
http://www.aemelectronics.com/exhaus...sensor-kit-641
The Boombop Shop
Mar 24, 2011 11:23 PM
TyCooley
Nov 18, 2007 08:48 AM
boostedh22a
Nov 25, 2005 12:29 AM
ImportHatch
Jun 19, 2002 08:03 PM
