map sensor questions
Old May 2, 2013 | 08:45 AM
CGcivicGSR's Avatar
Default map sensor questions
Question is I have a turbocharged h22 hatch tuned on hondata s300 I periodically getting am getting cel for map sensor its a hondata 4 bar map sensor. Question is can I run my stock sensor without making any changes in s300
Old May 2, 2013 | 11:17 AM
raverx3m's Avatar
Default Re: map sensor questions
check for lose conector or broken wire right before the connector?
Old May 2, 2013 | 04:38 PM
CGcivicGSR's Avatar
first thing i checked its a brand new rywire harness.
Old May 2, 2013 | 08:10 PM
raverx3m's Avatar
theres an option in s300 to select the map sensor. select stock
just remember that its not gonna read past certain amount of boost
or select the hondata sensor again maybe settings got corrupted or accidentally tweaked
Old May 3, 2013 | 07:20 AM
CGcivicGSR's Avatar
Ok ill try that after work just hit stock map and then the up arow
Old May 3, 2013 | 07:36 AM
CGcivicGSR's Avatar
GT500FTW
Apr 11, 2014 10:15 AM
lovey408
Jun 18, 2007 04:34 PM
beak
Jul 9, 2006 01:28 PM
lucidvtec
Jul 11, 2005 11:51 PM
b16 matt
Sep 21, 2004 07:00 AM
