D16y8 questions
Old Apr 21, 2013 | 04:54 PM
Shaneth95's Avatar
Default D16y8 questions
My 1998 Honda civic ex with a d16y8 started knocking. I immediately parked it, and wanted to save its life. It's a small knock, the car still starts, but it did suffer from a loss of power.
I'm wondering if I should just buy a engine rebuild kit and replace my pistons, rings, all the bearing, thrust washers and oil pump. I drained the oil, and there very little metal shavings.
I took the head off and it seems to be fine, and were no shavings in it. My pistons look flakey on top. I'm just wondering if this would be a fix. I haven't got it completely apart, but I'm just thinking since it would start up, drive and the knock was minimal replacing what I mentioned would solve the problem?
Thanks!
Old Apr 25, 2013 | 08:11 PM
bspeed's Avatar
Default Re: D16y8 questions
Wrong forum, knocking is bottom end not the head. You likely need rod bearings if you are describing this correctly. Don't wait for the idiot light to check your oil anymore.
Ryan Lwin
Oct 22, 2014 11:16 AM
Cerberus10411
Sep 11, 2014 11:00 AM
DAintegraGSR
11
Jun 10, 2008 07:48 PM
CRXracer88
Mar 22, 2004 05:59 PM
