ls-v stroker need help with basemap
Old May 27, 2013 | 09:53 AM
kurt707's Avatar
Default ls-v stroker need help with basemap
hey so if any body can help me i listed i think about every thing i got done to the motor. it would be highly appreciated if someone can give me some advise . im going to get it tunned but need to save up some mor cash.and need to drive it a couple hours south so need something to get me there..thanks so much kurt
b18b1 block
gsr b18c1 head
bore 3.209
stroke 3.740
displacement 1983cc
450 bisimoto injectors
teflon coated bearings
crankshaft 95mm stroke
billet crower rods 5.276 lenght
je pistons flat top 10.5:1
gsr crower vtec camshafts stage 2
cam gears crower adjustable
crower springs and retainers
golden eagle full vtec conversion
skunk 2 vtec soleniod
blue gates racing belt
skunk2 intake
bisimotto style header
stage 2 act clutch
act 11.9 lb. flywheel
greedy exhaust
walbro 255 fuel pump
hondata s300
aem air/fuel gauge
evolution ind. crank pulley
carbon fiber whale tail intake
oil pan stud kit
skunk2 composite fuel rail
type R oil pump
Old May 27, 2013 | 09:56 AM
grumblemarc's Avatar
The Grumpiest
Default Re: ls-v stroker need help with basemap
Wrong forum. You want PGMFI.org or the Engine & Management section if you're doing it yourself. Otherwise contact Phearable and have them burn you a basemap.
Old May 27, 2013 | 10:08 AM
Schister66's Avatar
Man U FTW
www.phearable.net
www.xenocron.com
www.j-k-tuning.com
Old May 31, 2013 | 11:39 AM
kurt707's Avatar
Ok thanks I'm new as you can tel thanks ill check it out
Old May 31, 2013 | 03:44 PM
Schister66's Avatar
Man U FTW
Any of the companies above will be able to burn you a base map for your setup. If you look in the www.hondamarketplace.com you can find them on Honda-tech. I have personally bought parts from each of them and would recommend any and all of them. Give them the details on your setup (like you did above) and with the S300, it should be pretty straight forward
Old May 31, 2013 | 03:48 PM
jbpnoman's Avatar
I'm personally a fan of Xenocron, just another toss in the hat for their name.
Old Jun 3, 2013 | 10:29 PM
kurt707's Avatar
Ok thanks again I'm going check it out. You guys are alot of help I really appreciate it. It makes every thing easier
s0_wavyyy
Engine Machining & Assembly
55
Nov 30, 2018 07:38 AM
Konigrx91
51
Dec 10, 2008 10:08 PM
allmotorek8
12
Sep 5, 2005 01:00 AM
GEN2TEG
Mar 20, 2002 09:42 PM
