results of my first tune need input
Old Apr 29, 2013 | 07:16 PM
si90rex's Avatar
Default results of my first tune need input
I'm new to tuning, this was my first turbo build and full tune, over sized injectors that is.
Mods
stock b20
custom log manifold
dsm injectors
turbonetics t3 turbo very small .48ar
no exhaust only down pipe under the oil pan
crank case vented
only 8psi
the car preformed extremely well, at the track i ran 13.3 at 113 spinning in 2nd with street tires.
My wideband stayed at 13.1 in boost.
motor still running when i pulled it apart, for a b20/vtec turbo. the pics are just after i pulled the head. everything is golden brown but the valve stems in the ports are whiteish in color. this was only a street tune. the nearest dyno is an hour and a half from here. should the valve stems be white? i have no anti lag setup.
Thanks
Old Apr 29, 2013 | 09:00 PM
raverx3m's Avatar
Default Re: results of my first tune need input
why you pull it apart if it was running?
Old Apr 30, 2013 | 09:20 AM
si90rex's Avatar
b20 vtec turbo
Old Apr 30, 2013 | 10:02 AM
98vtec's Avatar
moderator emeritus
Give it more fuel. I like to see 12.0-12.3 for low boost. And depending on the person who owns the car and if i know how spirited they are or if i can determine how likely it is for them to go on the interstate and make a 5th gear pull, I will sometimes run high 11's even for low boost.
Old May 3, 2013 | 09:38 PM
si90rex's Avatar
ok thanks i have a gtech and it would make less power at 12.5 or lower. but traction is a huge issue so it may not be spot on. I havent messed with the timing yet just retarded the timing .75 degree for every pound of boost. Im just playing it safe while i slowly push the car.
Old May 3, 2013 | 09:47 PM
98vtec's Avatar
moderator emeritus
please do not rely on your gtech.
Old May 4, 2013 | 06:32 AM
sicones's Avatar
Gtech? Yeah, don't use that. Your AFR is lean for boost, should be in the high 11 area. Motor looks fine, why take it apart?
Old May 4, 2013 | 08:28 AM
gaby-dr's Avatar
THAT VALVES COLOR IS BECUSE THE ENGINE IS RUNNING LEAN, YOU SHOULD SET YOUR A/F TO 11.8-12.2,
Old May 4, 2013 | 10:38 AM
si90rex's Avatar
it was a stock b20 but i have b16 head i assembled with new everything so i wanted to switch it out. I ll make some adjustments to my new setup when i tune it.
Old May 5, 2013 | 08:26 AM
Gunmetal_B20_Hatch's Avatar
13:1 is too lean in boost(even low boost). You need to be down in the 12.0:1 range for low boost.
What are you doing with the P8R?
Old May 8, 2013 | 11:51 AM
SpoonMotorSport's Avatar
your motor looks healthy and fine but those plugs are a little lean for boost! even for NA i'd say 12.5afrs on wot and your peak tq should also rise you'll be fine better be rich than lean and plz do check your plugs after every tune! if you have a good eye your plugs can save your engine! cheers
typhoondriven
May 21, 2008 11:21 AM
ral24_hct
Apr 30, 2006 06:32 AM
builtB20turbo
Jun 26, 2004 11:13 AM
Ri5e
Sep 8, 2002 06:07 AM
