Neptune issues
Old Jun 16, 2013 | 09:29 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Neptune issues
ECU talks to the laptop and controls/reads the sensors, but does not seem to see the VR signal and does not fire the injectors. nothing in the car changed since the car ran last time, could something have died in the ECU?
Old Jun 16, 2013 | 09:58 PM
HRTuning's Avatar
Default Re: Neptune issues
If you're not seeing a signal in logging there's a problem with that sensor or wiring for it. If you're not seeing RPM it's likely wiring or your Anti-Theft settings.
Old Jun 18, 2013 | 10:05 PM
Antitheft! I haven't checked that. It's not wiring. The car ran before I attempted to load my tune to it.
Old Jun 18, 2013 | 10:07 PM
I will give you more info to ponder. I had comm issues between the demon and the ecu. If you remember. I re-seated it and the car ran. The demon communicated and I then proceeded to load my "ok" tune onto it. That's when the car sputtered and died and will not restart.
Old Jun 19, 2013 | 07:05 PM
HRTuning's Avatar
It actually can be wiring if you're not seeing RPM during cranking but other sensors are showing live values. That or Anti-Theft.
littlebill
Mar 17, 2007 09:20 PM
sidewalkserfer
Honda Civic (2006 - 2015)
16
Jan 6, 2007 04:06 PM
OutlawCL
Feb 15, 2005 10:09 PM
