RPM based timing compensation??
Old May 15, 2013 | 09:06 AM
a1320honda's Avatar
Default RPM based timing compensation??
When i was going through my log, i noticed that the "actual timing" and "table timing" were off by nearly 10* at 9000rpm. As i looked through Crome, Neptune, and Hondata, I noticed that they all had some sort of table setup to advance timing over what the table timing was based in RPM. Was just curious why this is. I found some guys on the Neptune forum saying that needs to be set to 0 across and just go off of table timing. Any insight would be greatly appreciated.
Im referring to the last table in this screen shot in Hondata...
Old May 15, 2013 | 03:52 PM
Gunmetal_B20_Hatch's Avatar
Default Re: RPM based timing compensation??
I dont really understand the need for a separate table... Just zero the table out and tune off the main map.
Old May 15, 2013 | 05:44 PM
odz-fab's Avatar
correct me if im wrong........the section you have shown is related to ignition dwell angle.... not actuall timing.
Old May 15, 2013 | 09:33 PM
ThE HeLLRaZoR's Avatar
I have never played with Hondata so I maybe wrong? But, the RPM Compensation looks like your problem. That being a Trim table I would think 14.75adv@8000rpm is adding that on top of what the Ignition Map is already doing? I'd findout about that table asap. I honestly don't see the point to that other than making your actual Ignition Map more Flat, if thats the case and it's tuned properly you shouldn't have a problem but idk? GL!
Old May 16, 2013 | 06:10 AM
xenocron's Avatar
Yes it has something to do with Dwell, its an OEM table...personally I just leave it alone and tune the car for MBT
Old May 16, 2013 | 06:19 AM
HRTuning's Avatar
Xeno knows what's up. This is really what you should be doing.
Let's face it. These distributors aren't accurate at high RPM and the ECU needs to compensate. I give access to the "Actual timing" output in NepTune so you can see everything the ECU is doing behind the scenes. If you don't understand it, don't mess with it!
JDMlyfestyle
23
May 19, 2008 05:52 PM
brandond
Jan 16, 2005 07:21 PM
GReddy SI
Sep 8, 2004 01:25 AM
hybrid901
Sep 18, 2003 12:53 PM
GruvyTune
May 9, 2003 03:37 AM
