identify these pieces, pics
Old Apr 29, 2013 | 09:16 AM
balbowskie's Avatar
Default identify these pieces, pics
Intake control solenoid valve on a 1993 Honda prelude si. Boosted. This piece has been hanging around for awhile I don't think I need it anymore. So I was goin to unplug it and take it off.[IMG][/IMG]
Old Apr 29, 2013 | 09:18 AM
balbowskie's Avatar
Default Re: identify these pieces, pics
Also I've found that this piece I glued on broke again do I really need it at all? Bypass control solenoid valve?[IMG][/IMG]
Old Apr 29, 2013 | 01:54 PM
balbowskie's Avatar
Bump
Old Apr 29, 2013 | 03:50 PM
VegasInvasion's Avatar
I'm Huge In Japan
it looks like the IAB vacuum tank and solenoid. if you don't have an IAB intake manifold, remove it. and sell it, some people are looking for those.
*edit*
Just saw the IAB diaphragm, you do need that and your top end will suffer if it's not operational. But if you're boosted it might benefit you to remove the IAB butterflies and remove the box, especially if you're not using an IAB-enabled ECU.
Old Apr 29, 2013 | 04:05 PM
balbowskie's Avatar
I have a IAB manifold though, its the factory h23 manifold on my si. Can I hook it direct to the intake manifold even though I'm boosted or get a new black box or can I take it off or, unhook it?? Anyone know a quick fix with no power lose?
Old Apr 29, 2013 | 04:54 PM
balbowskie's Avatar
Can I just keep them in the open position all the time so I don't have to tear it down to remove them or should I rip it down and take them out? I am running a p75 ecu odb1 and hondata s300
Old May 8, 2013 | 09:32 AM
I'm Huge In Japan
just install the IAB circuit. you can't hook the IAB directly to a vacuum source or it operates in the reverse manner it's intended for. You can leave it disconnected but the top end will suffocate. worst case scenario you can remove the butterflies, but you'd be better off getting a different manifold since your low end will be soggy from the turbulence in the plenum.
Old May 14, 2013 | 07:39 AM
sleepyaccord96's Avatar
remove the iab solenoid and the air box control box. none of it is needed.
i have iabs on my h22's but i run a vacuum line straight from it to the IM so that when you press the throttle more than 30~% they open.
Old May 20, 2013 | 04:48 AM
balbowskie's Avatar
I'm goin to unhook it then and if I don't like it I will goto the IM and they that.I don't see that they operate in reverse. Looks to me the more vacuum the more that open. But I just installed a turbo and I believe that's goin to mess everything up if I use them since the positive pressure in the IM rather than vacuum. Any ideas, better left in hooked???
Old May 20, 2013 | 11:24 AM
cruizinmax's Avatar
Not positive on the H series stuff but the way the IAB on a GSR manifold works is that black canister you're holding stores vacuum from idle/part throttle driving then when the ecu signal's the IAB's to open, a solenoid allows the stored vacuum to open the IAB vacuum pot, then opening the butterflies. With no vacuum the butterflies stay closed therefore on the long runners for low RPM.
Some guys physically wire the butterflies in the open position but low rpm operation will be slightly worse. On my GSR I did not notice the low rpm loss on the "butt" dyno.
Old May 20, 2013 | 01:24 PM
balbowskie's Avatar
So to say if a turbo is installed then the IABs will not function correctly and need unhooked.is this statement correct? In know mine are open when the car is not running, I also know buy using a separate vacumm while cars not running I can close the butterflies. So its spring loaded in the open position now.
Old May 20, 2013 | 04:17 PM
balbowskie's Avatar
https://honda-tech.com/forums/honda-prelude-4/prelude-intake-maniflld-flapper-valves-3142881/
Old May 21, 2013 | 02:28 PM
cruizinmax's Avatar
Turbo or not doesn't matter, the canister stores the vacuum with one way valves then uses that to actuate the butterflies when there is no vacuum in the intake manifold. (WOT/boost)
balbowskie
Apr 29, 2013 04:08 PM
ccornell
Jan 23, 2011 05:44 PM
sivikvtec
Apr 13, 2007 07:29 PM
JDM95lude
Oct 14, 2006 08:21 AM
