2step question
Old May 12, 2013 | 07:41 PM
keith1993may's Avatar
Default 2step question
now before u go n say google it. i have many times n couldnt find an answer. i recently got an aem n got it tuned with 2step at 3500rpm.. what exactly are the steps to make it work? normal operating temp? in first gear completely stopped n floor it right with clutch in? just checking because it seems mine wants to work when it wants to. maybe im letting off of it thinking its not gonna work? could something have happened when he tuned it for the 2step?
note- i do not have to hold my clutch in to crank the car.
Old May 13, 2013 | 02:34 PM
GhostAccord's Avatar
Default Re: 2step question
You would have to ask your tuner to know exactly how it is set up.
Old May 13, 2013 | 02:44 PM
i called him. he said its ingition cutoff through the speed sensor. no clutch involved. i cant be going over 3mph. its still working when it wants to.
Old May 13, 2013 | 03:21 PM
now the guy i got the car from just told me that the ignition went out on him one day n he rigged it up so he can get home. popped the cover off and there a wire running and connectiong 2 different wires. pics up once my phone charges. maybe thats why it works only sometimes?
Old May 13, 2013 | 05:20 PM
alright heres the pic. the black wire is the wire that was rigged up. so i was told. and if i disconnect one end of it it will crank but cut off right after. do i need to replace ignition switch or the switch and wiring harness? could this be causing my 2step not to work most of the time?
Old May 14, 2013 | 05:34 AM
kyden's Avatar
replace the switch. the harness comes with it.
Old May 14, 2013 | 09:01 AM
in the process of trying to find one now used locally in nc..
Old May 14, 2013 | 11:50 AM
i think i figured it out. so i was tapping the gas while in first n stopped. 2step activated. tried it 3 more times so far just playing with the pedal and its been working. hell i thought u had to floor it for it to work
Old May 15, 2013 | 09:37 PM
odz-fab's Avatar
no flooring needed....as long as your speed sensors is below the adjusted speed. after that speed everything works as normal... in the case that your speed sensor fails or cuts out you will be limited to the 2step rpm
Old May 15, 2013 | 09:56 PM
ThE HeLLRaZoR's Avatar
The wire was probably from a stupid Kill Switch? When you loose the Jumper Chip you have to just rip the switch off and tie the wires togather as he has done here. Had this problem on my old DA. This has absolutely NOTHING to do with your 2step.
If he set the Threshold to 3mph this means you need to basically be at a DEAD STOP for the 2step to activate. If your rolling even the slightest this could cause your ecu to think your going 5mph. The VSS doesn't have the best resolution. So just make sure your at a complete stop!!
It doesn't matter if your Clutch is engauged or not. For it to work like that you would need a Wiring Mod and I don't see why he would do that if you have a VSS. All that matters for your 2step to work is your at a DEAD STOP aka not even rolling the slightest
noxon511
Mar 15, 2014 08:42 PM
ai95
Jun 12, 2004 06:14 AM
94sisol
Aug 11, 2003 01:03 AM
erikgsr
Oct 20, 2002 10:45 AM
schumiR
May 25, 2002 05:57 PM
