Rywire sub harness help!!!!!
Old May 11, 2013 | 10:14 AM
Jmx305's Avatar
Default Rywire sub harness help!!!!!
Hey guys! I'm going through bit a of a problem installing my rywire sub harness. I know the sub harness plugs into the driver size shock tower and then it plugs to the engine harness. The problem I'm having is taping the 6 or so loose wires that the harness comes with. I know those wires are for the fuel pump, vss, and ect. I'm not sure where I'm suppose to tap them. Rywire says I'm suppose to tap them to my old ecu plugs. I did that but nothing, everything else is hooked up and ready to go. Note that my car has been setting for a bit but I doubt it has nothing to do with.
So those are the wires that need to be tap and the others are my old ecu plugs. So I just tap them through there's or am I suppose to do it somewhere else? I'm really confuse. I'd looked everywhere for a definitive answer but nothing. Any help would be greatly appreciated. Thanks!
Old May 16, 2013 | 08:08 PM
unspankable's Avatar
Default Re: Rywire sub harness help!!!!!
Hey dude!
I'm doing this exact thing right now.
What car is it going into?
Old May 16, 2013 | 08:16 PM
Does the Subharness plug into the driver side shock tower of an integra too?
Old May 20, 2013 | 07:54 AM
Jmx305's Avatar
It's 93 cx hatch. I tap all the wires like I'm suppose to and I everything works like my check engine light and all that stuff which are part of those 6 loose wires but my pump still doesn't prime, so I really don't understand. I think the integra should be the same. Did your harness came with two sets of wires? The subharness and the engine harness? As far as I know they should be the same
Old May 30, 2013 | 02:46 AM
swordofdoom's Avatar
What kind of idiotic company uses the same color wire for all the wires?
Old Jun 7, 2013 | 05:23 PM
juba_x's Avatar
Did u figure this out just didn't mine and fuel pump doesn't prime
Old Jun 7, 2013 | 06:12 PM
Blown90hatcH's Avatar
Look under your dash at the connector with all the wires of the same color......
It's common to use the ground bar with all the same color wires or the power bar with all the same color wires.
Old Jun 7, 2013 | 07:01 PM
You don't use the same color especially if its for a different purpose unless your broke.
wfocrx
Apr 30, 2015 05:56 PM
obuhmyuh
Oct 2, 2008 10:51 PM
Superhatch
Jul 10, 2002 04:37 AM
