s300 led blinks
Old Apr 12, 2013 | 12:34 PM
bodenman's Avatar
Default s300 led blinks
i installed a plx wideband and it ran fine i went into smanger and set it to closed loop to replace my stock o2 with the new wideband and now my car clicks and the ecu blinks and if i try to connect to it the led turns red did i blow something
Old Jun 10, 2013 | 10:51 AM
VegasInvasion's Avatar
I'm Huge In Japan
Default Re: s300 led blinks
probably. sounds like your wideband isn't wired correctly. remove the wideband, check your fuses. if the LED is still red, you fried the s300.
Old Mar 1, 2014 | 02:15 PM
bodenman's Avatar
it turned out I had a corrupted software update I reinstalled smanager and was finally able to upload a good upload to the s300 and all works fine now nothing fried
Goose_Fur
Sep 29, 2008 06:26 PM
stockgreencivic
Feb 19, 2005 10:43 PM
el es vtec
Apr 13, 2004 08:09 PM
djmatix
Mar 6, 2002 03:34 PM
