JDM b16a no vtech
Old Jun 4, 2013 | 05:57 PM
JDMB16aEFhatch's Avatar
Default JDM b16a no vtech
I installed a usdm b16a head gasket on my JDM b16a now Vtech wont work? Is the gasket the reason? If it should be working with the USDM gasket then I will start pulling codes. I know all the most common reasons why Vtech will fail. I have looked into most. If the Gasket is not compatible i'm sure it's due to oil pressure issues. Also FYI Since I have a JDM B16 I have no oil pressure gauge. So I have no Idea if I am getting a drop in pressure.
Old Jun 4, 2013 | 07:53 PM
mikekh10a's Avatar
Default Re: JDM b16a no vtech
do you have any CELs?
Old Jun 4, 2013 | 09:48 PM
odz-fab's Avatar
b series vtec head gaskets are the same.
recheck wiring.
not sure if its possable to install head gasket upside downor if that would even block any oil passeges
Old Jun 5, 2013 | 10:49 AM
So there is no dif between JDM and USDM?
Old Jun 5, 2013 | 10:52 AM
JuggerNaut-CTR's Avatar
Difference like what? Why would there be? They are all the same motors with a couple small bolt-on differences.
Old Jun 5, 2013 | 10:53 AM
It's not throwing any codes.
Old Jun 5, 2013 | 10:55 AM
Did you forget to put back in the o-ring under cam cap #3? That could cause no vtec with no cel.
Old Jun 5, 2013 | 11:04 AM
speedooo's Avatar
My money is on lack of o-ring. I've had a handful of friends do that on many occasions. Usually vtec will engage and immediately disengage.
Old Jun 5, 2013 | 11:13 AM
I know I read in another thread that there is a dif between the two gaskets. That the USDM has an oil pressure gauge, the JDM dose not. So the gasket on the JDM has an oil passage in it that the USDM dose not. I just need to confirm this. If there is a plug I can remove from the head can I re route that oil passage? I believe this is one of those bolt on differences that is effecting me. I may be wrong but I'm not throwing a cell. But I have not tried throwing a code while at 5,500 rpm when vtech should be kicking in. I'm getting speed signal to the ECU, I have oil pressure, I don't think I have a bad thermostat. My wiring is good as well.
Old Jun 5, 2013 | 11:17 AM
I am going to check the O ring thanks for the info.
Old Jun 5, 2013 | 11:18 AM
Whatever you think you are reading is wrong. ALL dohc vtec bseries head gaskets are the same.
Old Jun 5, 2013 | 02:35 PM
Ok thanx for confirming that.
Old Jun 7, 2013 | 09:16 AM
I think my ecu should be throwing code but my set up is jank. I have three wire coming hooked up to it (this is how it was when I bought it). The guy told me I just ground the orange wire and touch the red and blue together. I tried still a solid check engine light. I have an integra wire harness and it's pretty raggedy. So I started looking at all my sensors. I found that the sensor on my thermostat is snapped off. I am a nuub but this is my first car like this so I'm trying to learn. Is that the engine coolant temp sensor? Would that being broke off cause my vtech not to work? It is also using gas pretty bad. I had a friend do the gasket job. Vtech worked before he did the gasket. Now it don't.
Old Jun 7, 2013 | 09:56 AM
If the coolant temp sensor is broke off and the ecu thinks the motor is cold, vtec will not engage.
Side note....curious what the 'h' you are placing on the end of vtec means?
I'm going to get the sensor tomorrow.
Old Jun 7, 2013 | 09:58 AM
IDK guess cuz I'm ignorant as hell.
Old Jun 7, 2013 | 10:00 AM
Thanx for the info though man. Hope this takes care of it.
Must be....never seen someone be corrected a few times from thread to thread and still call a function of your motor a kids toy or a phone. Cracks me up. Does it say "vtech" on your valve cover?
tavo.760
14
Nov 19, 2013 10:50 PM
z6htch
Aug 30, 2009 02:31 PM
wood 1
Aug 31, 2007 01:29 PM
omg_miiiike
Apr 27, 2005 03:34 PM
92CivicSiR2
Oct 11, 2004 04:05 PM
