AEM and Injector Timing.
Old Apr 27, 2013 | 03:29 PM
ThE HeLLRaZoR's Avatar
Default AEM and Injector Timing.
Hey HT, working with a AEM 30-1050 and Gsr Motor.
Block mods:
Sleeved 84mm, Machined Flat(Don't know how much was taken off, not much the motor only had 75k when build began).
Head mods:
Machined Flat(same storie as block)
Ferria .050 over Valves.
Stock GSR Cams and Gears currently.
So my question is:
Is there a way to adjust Injection Timing in the Software. I'm thinking it would be done by adjusting the Injector Phasing option. But, i'm not sure.
I don't know how much these mods would affect Injection Timing. Would you guys recommend having the Cams Degreed? Thanks for any Advice given
Also if anyone has a good video link on how to degree cams please post it as, that is something I want to eventually do regarless.
Old Apr 27, 2013 | 08:23 PM
mtber's Avatar
Default Re: AEM and Injector Timing.
If you are using a stock distributor pickup you do not need to mess with the injector phasing settings.
Concerning your cam timing, you are using stock cams & gears.
Get some cam gears and compensate for the head milling etc.
Old Apr 28, 2013 | 07:28 AM
I'm using an EPM, Twin Fire and the Pencil Coils.
xxxmikenicexxx
Jun 17, 2010 05:54 PM
wicked_b16eg
Dec 27, 2007 06:05 PM
all-mtr-teg
Jan 12, 2007 09:25 AM
PhazedSI
Sep 19, 2003 06:54 AM
incognitoracerr
Apr 22, 2003 12:47 PM
