- D15b vtec rod/piston combo that doesn't require boring the block?
- ACL oil pump D16
- Oil Expander/Spacer End Gap too large?!
- Where to buy/ Resurfacing rockers?
- gap between rod and inside of piston
- D16Y7 Photos of Plastiguage results for Crankshaft Main Bearing Clearances. Any good?
- Having issues with my Built B18C5
- Choosing Piston Rings. Standard Rings Don't Fit? '96 Civic - D16Y7 Engine
- My A3 to A2 block conversion
- confused with ARP head studs for D16Y8
- Stripped header nut. Ideas/help?
- Bought a remanufactured crankshaft and there is a nick
- Block Girdle usage?
- K20A3 With K20A2 Internals ?
- b18b1 block, b1 crank, b18c1 caps/girlde. Bearings?
- Corrosion in block
- aebs main stud blueprint
- h22 freeze plugs
- D16 eco stroker build questions
- D16Z6 or D16A9 ?
- Bisimoto f20b forged piston specs.
- rebuild kit for b18c1?
- H23A VTEC BlueTop / H22A7 rod, main torque spec
- B16a2 cylinder scoring
- Degree cams after short block build?
- Wrist pin question
- Help ID Cams
- Engine builders!! Recommend me a Vernier
- Head Gasket - Does it need to be thicker after head and block resurfacing?
- Block post bracket bolt hole repairs
- Nrp 0.50 really 81.50
- Is this crank usable?
- Looking for good machine shop in Simi Valley or San Fernando Valley
- replace oil pump?
- Help identify this crankshaft
- Stripped headbolt hole....
- Tell me what I can do
- gouge on cylinder head
- Bent crankshaft
- Is this head cracked?
- B20 block still good?
- B18C1 Rod cap on backward?
- B18a1 exhaust valve seals?
- 84mm piston question(s)?
- D16 waterpump idler gear?
- naked b16
- can this block be salvaged???
- Adjust valve lash with your engine HOT! - Not OEM camshaft!
- gsr spun bearing and using ls internals?
- rods and pistons don't match up
- engine cleaning brushes
- b16a2 mix match rods
- B18b1 cylinder head welded/sealed???
- b16a2 main bearing caps torque spec
- b16a2 valves springs price
- B16 EAGLE RODS bearing crush hight
- Leaving a built motor sit
- NC engine builders
- sleeved b20b, hole in block
- Happy 1 year anniversary to the "Engine Machining and Assembly" forum!
- another honda bearing
- camshaft crankshaft rocker arm
- engine gurus i need your wisdom
- H22 P2V clearance check
- Crankshaft run out?
- Newly built b18c1 with low compression
- Need some help building
- Best Place to get a B18 FULLY Sleeved and Built/Assembled?
- Oil squirter/cooler sleeved application
- Fully built b20b losing compression
- Bad oil leak after ls vtec assembly
- No block notching
- how to separate tranny from the motor
- H22: unmarked crank, bearing codes?
- Best k series head for porting
- B18c5 need headgasket 82m work
- Too much bearing clearance??
- My b20v dyno numbers
- help me identify these valves
- Fair quote?
- B16 head with LS valves
- b16a2 compression test question
- Ccs or filling block
- Question about electrolysis!
- B16 PR3 rods in a B17 block/crank
- Cam cap bolts breaking
- p61 rod broke need a replacement
- Good Machinist Near Houston TX
- Best and easiest way to clean the head and block after they've both been decked
- Info on how to test valve springs
- D16z6 monroso oil pan
- CTR Piston
- GSR Camshaft Holder Plates
- LS VTEC HELP!
- GE Headstuds Lube?
- ring gap..Need help!!!!
- Leak down on engine with new valves.
- H22 88.5mm bore, which head gasket?
- Bearing question?
- oil flow diagram?
- H23A VTEC rebuild. Blue top.
- Building a b16a2
- Flex a hone
- Engine bearings
- Breather kit install
- possibly a very stupid question idk
- Chopped valve guides b16a head, bad?
- B20b vtec rebuild gasket kit
- Fel-Pro Valve Seals Question.
- Misc bolts?
- Cam Journal Repairable?
- K20 series or R18?
- Flywheel bolts D16Z6, NEED... Columbus, Ohio
- b20z2 milled gsr head ptv questions
- Ctr cams in a regular b18c?
- What is a 1/8'' NPT Tap equivalent in metric ?
- arp pr4 rods full floating in turbo build.
- sleeving where they add the 3/4" taller deck
- Anyone use complete "engine rebuild kits"?
- Rebuilt block sitting
- best engine builder in the Carolina/Georgia/Florida area?
- B16 retainers question
- damaged a6 cam
- Assembling the pistons, wrist pin to the rod
- Mystery part number 14!
- Where do you guys buy your oem honda bearings from?
- nicked / pittted on cylinder head - right on bore
- Engine smoke woes d16A
- Cam break in...too late?
- LSV vs GSR
- How much cylinder taper is TOO MUCH? 92x85 b18C
- B18a1 gsr head swap
- Sleeves for b18B
- under/oversized bearings
- Squish Zone/Quench Area
- B series Aftermarket Bearing Thickness Information
- How do I clean this?
- Semi built LS-V for turbo
- Overall Feeling of Engine Machine Section
- Cometic HG - copper spray yes or no?
- B16 Boost / LS Boost
- P2W clearance for 81,5mm YCP b16 build
- Question about balance crank
- D16y7 with d15b8 head
- Need info asap B16-B20
- Spun Bearing on B16a2.....(oversized bearings)
- Lock groove location on Ferrea valves
- Well my new rear seal leak installed like this?
- Fun Build?
- Bearing Inspection and Rule of Thumbs
- DYI rod bolt stretch gauge. 3 dollars total cost
- H22 rebuild question
- Valve nut spins with screw
- B series oil pump relief valve question
- Cam verification
- Valve Weights OEM B16 vs Ferrea 6000
- Junior's first build lol
- Noob P2D question
- NEW !! CNC Port/Block Machine !!!!!! Centroid A560
- wrist pin bushing squished. bad or normal?
- Block rod and piston combination
- Engine storage?
- checking condition of bottom end
- Valve Guide Damage Question
- Crankshaft
- B18a surprise bored to 84.5 HELP!!!
- cold weather engine assembly
- Please help with this JDM B18C part :(
- F20C crank on a f22C stock block
- bearings measuring what method you use?
- 200whp b16 (millionth thread)
- pr4 rod question
- Bore ideas
- Throttle body
- GSR girdle on B20, do 1 & 5 caps go too?
- HeadGasket replacement AGAIN
- My first build
- honda bearing question
- H23A1 engine knock on decel?
- quick flex hone question
- B vtec rocker arm pad machining
- h22 swap Throttle problem
- Valve stem compressor in a very cramped c1 head
- B16A Engine
- Bored out aftermarket 2.0L Sleeves, What head Gasket?
- I'm trying to get some quality head in my closet
- B16a rebuild
- Pcv re routing?? h23 plug??
- B20/Vtec engine torque specs
- B18c4 swap problem
- B18c b20 build for boost
- oil orifices locking rocker arm rod in place?
- LSv dowel pin fitting issue
- Can aftermarket Sleeves be bored out?
- B18b1 valve seals
- b18c5 pistons in b18b block
- Name this sleeve? Need help
- does all p2j heads have raised quench pads?
- Bad crank pulley?
- H22a7 Mahle gold compression ?
- need help to timing d16a3
- Broken D16 Valve Cover Bolt Stud
- Bisimoto 3.6 cam install
- In need of ***PROFESSIONAL*** opinions...
- 3.7 acura pistons,,,,,,,,in a 3.5
- P73 piston safety vs Nippon?
- b18c5 w/supertech valves ?????
- maximum milling on head and block
- Just learning
- DNJ components rod bearings opinions?
- Main bearings .003 - anyone?
- H series and F series oil pump priming?
- Lint and Foreign Material
- Valve Damage
- Can anyone clarify this for me, plz? ***(F22Bx related)***
- Lsv turbo supertech
- Setting time on gsr with crower valve springs issue
- ACL Bearings Made in China!?
- piston ring gap question
- Ls Vtec build wait for ........ TurBo ! 🔰
- Crower Cam Specs not matching up
- B20B, B20Z piston rings are the same?
- Ls vtec conversion question
- Wiseco piston ring compressor
- Threaded water tube on my gsr head. Tq spec
- ACL bearings B18c
- F22B piston ring order?
- i noticed this upon engine tear down...
- B18 Questions
- B18c1 Brian crower valve spring install question
- Porting head
- B18C1 exhaust port questions
- Oil in the Cylinders
- Block cleaning
- zero decking and piston/rod balancing?
- D15 crank bearings
- cam bearing 2nd opinion
- can my h22 head be repaired? p2v damage
- B18 Intake Camshaft scratches
- crank issue, thread damaged
- b series valve stem measurment. anyone?
- Rebuilding D16Z6 Cylinder Head
- Skunk2 Alpha Rods
- Engine Building Hand Tools
- B20v high comp, N/A, or B18b1 ~430whp?
- help, water pump pulley back off snout g23 build
- Honing rods to change bearing clearance
- B20 vtec rod bearing clearances recommend?
- 97 civic DX swap d16z6
- Crank hard to spin but easy once it gets going?
