- b series block plug
- F23 Frankenstein help... PLEASE!
- P2W clearance with CP pistons
- Looking for a diagram or a parts list for a b18c5 cylinder head
- B20v with b16 arp head studs?
- B16a dropped a valve. What's the next step?
- Darton Dry Sleeves question
- What is the flatness limit of head and deck? Are resurfacing necesary?
- B20B motor dry compression test, one cylinder low
- Rod/Stroke Ratio - B16A Vs. B16B
- Father/son B16 build specs and questions
- H22 head oil gallery thread
- Need opinion on used head
- Checking b20 block for warpage
- B16 valve springs in b18b1
- Any builders to comment on Valve head size vs Stem diameter?
- Looking for a shop in central FL to degree cams
- How long may a freshly rebuilt engine sit without running?
- Stepped LSVTEC dowel pin EX side location
- royal purple assembly lube questin
- Engine Cylinder Head Gasket Oil leakage at time of Tesing
- B18b1 into ek won’t start help
- B18c5 help
- B18b1 - Damage
- I need some help with springs and retainers
- Need Valvetrain advice, thanks.
- B18c1 Build help
- B16A3 83mm
- Changed to Morosso oil pan w Fel-Pro gasket. Pan now leaking?!
- Driving with flywheel exposed. Problem? (JDM GSR w S80 ITR trans)
- b16 head - rocker arms stuck. need help!
- Installed Morosso baffled oil pan - need two-piece lower trans brace
- b16 arp head bolts seeping oil between head and block
- ACL bearing HX marking identification
- B Series OEM Rod Bolt Stud Thread Pitch?
- RODS probe industries or rpm racing parts maximum
- Mystery Bolt
- B18c1 rebuild help fo a honda noob
- J30A4 Stroker
- 625+ and rod bolt stretch.
- High HP GSR assembly / Question
- Looking For An Engine
- Head building and rev limits
- Searching for camshaft measurement software for valve movement
- ARP main studs-crank won't turn
- Scratched pistons
- B20Vtec sucking oil over intake valve stem seals
- Im wondering if you can use a h22 crank in a h23 block
- gsr crank vs typer
- Knowing your Motors Compression Ratio
- L15A1 (07-08 Fit) VS. L15B7 (17-18 Civic Si)
- Main bearing housing tolerances
- Pics:What do you think about this scratch on a freshly rebuilt gsr?
- Sleeves for h23 Jdm?
- H22 Oil pressure relief valve tension question
- D13A2 MOTOR SPECS NEEDED!!
- Rod bearing question
- Cometic headgasket leak
- B18c1 valvetrain upgrade
- JE 84mm 9.0-1 pistons in ls? Help pleaze
- Comp cam 89012 kit same springs as oem??
- Stupid noob question, but Search did not answer it...
- What rings to use on pistons
- Reman crank wtf?!?
- The use of ls rod bearings instead of gsr rod bearings
- Prelude SH startup for 6 seconds then dies.
- Piston clearance
- Head gasket size
- 2001 Honda Accord swap
- overheating issues from blown pistons
- B20 compression ratio math
- Assistance Needed: How to Degree SK2 Pro 3 camshafts
- Parker parflex microweld tubing?
- Pics *what's this sealant type material around the block guard?
- did I just doom my engine to self-destruction?
- Machine Shop/Engine Builder near Austin, TX
- Knock noise after rebuild B16
- Torque plates?
- can weak valvesprings cause a misfire at idle?
- GSR Build for 800whp+
- Torque Data Error for Intermediate Shaft to Engine Block-Is it 29lbs-ft?
- Cam Timing setup questions
- Honda CRV cracked block has an oil leak. How cam I repair?
- skunk2 camgear degree question
- D16 Darton sleeves water leak problem
- Stuck Degreeing Cams H22
- Is it necessary to re-degree camshafts after changing cylinder heads?
- Pr3 with .25 overbore
- Best B16A Gasket/Seal Kit & CKF
- Think this is the right section 🤔
- Cam Cap O-ring
- D16 ring gaps haven't found a solid answer yet.
- What all is involved in a rods/piston install on a B18?
- Engine test stand (run stand)
- D16 Head Measurement Needed
- ARP bolts on Manley rods
- one head bolt was loose?
- Broken Piston Rings / New Rings Question
- help with scratches on cylinder wall
- Machinist in Sacremento Area?
- Replacing Oil dipstick tube B16a
- Mid-Atlantic/DMV Shops
- Vtec Solenoid Internals
- B20 vtec help!!!
- Piston to head -Turbo - milled engine. I killed my brain.
- Preparing for Rebuild - Oil on Spark Plug Wells & Pistons
- Replace valve seals on JDM import motor?
- Evergreen stock rebuild kits?
- H23 build questions
- Worn valve guides or scam?
- Valve Guides
- What is this from and how did it get to my oil filter?
- Do head studs reduce the chance of a head gasket failure?
- Good machine shops out west? + PTW questions
- Sleeved GSR Block Manley Rods Question
- HELP!! This isn’t normal right?(Pistons)
- Piston Advise Please!
- OEM oil pump rotors/gears
- Is this a cracked/ruined block?
- b20vtec build check and gasket set recommendations
- Torque Settings
- Vtec cam plates/"pipe" holder
- B16 and B20 Rod and Piston Specs
- B16A headgasket same as b16a2?
- Troubleshooting: Does this connecting rod look usable?
- K24z1/k20z3 head block oil squirters needed?
- Needing machine shop in Charlotte area
- Mixed up rod caps?
- Can't find these bearings in ACL's catalog - D16z6
- Y8 block z6 head aem cam gear problems
- SOHC ZC Issues
- b20vtec recommendations
- 03 k20a3 fit a2 cams??
- B17 crank, b18b block, b16b or custom rods, b18b or custom pistons
- 99 civic si clutch line
- b16a2 new swap
- F20b and F23 Frankenstein question
- Help reading block stamp for bearings D16
- Can't figure out engine noise after rebuild.
- New engine high compression test
- Darton Mid Sleeves vs CSS 850++
- Assistance Needed: B20B Block/B18C Crank -Main/Rod Bearing Selection
- Preparing for hg install, rebooted
- questions concerning valve lash b18b
- Damage on block...re-useable or no?
- Engine rebuilder/builder in Southern California?
- Honing B16a2 rebuild
- 1999 prelude engine swap
- Complex F/H-Series Balancer Shaft Discussion
- Worn cam caps
- Mix matching main caps on a b18b1
- Info Request: Main & Rod Bearing Torque Specs for the H22A Euro R
- Struggling to understand bearing selection
- well my rod bearings are too tight with acl hx's
- Piston rings
- Ring issue- what to buy 81mm b series
- JDM B18C Rebuild
- Piston ring availability for Arias Pistons
- Beginner machinest tools
- Cam surface ate itself
- rod big end bore help
- Not the most exciting engine swap
- Degree'd my S2 Pro 1's
- engine rebuild question
- PR3 Pistons in B18C Type R JDM
- GSR with ITR internals parts list
- Michigan boring and honing service
- Assistance: Recommended Wiseco Piston-To-Wall Clearance For 800hp F22C
- gsr build dropped a valve (opinions? )
- H22 thrust washer won't fit
- PM3 pistons, Z6 block, B7 head combo..
- Does anyone know what this is???
- D16 Newbie rebuild, how does my bearings look? Pics*
- Oversized Piston Rings
- Are these sealed power?
- 1997 acura integra ls auto
- Darton sleeve install on D16 block (Sleeve height)
- Built LSVTEC oil pressure issues
- Rod bearings offset
- Need help!!! H23a swap with pics
- ROD BEARINGS WEARING ON EDGES
- Performance
- H22 head super tech help
- Anyone experience problems seating Hastings chrome rings
- Skunk 2 Pro 2 quick settings
- can some elaborate more on rod resizing
- B16a2 Pr3-3 journal scoring
- B18a1 block, jdm b16 head ls vtec
- Failed leakdown after new gasket and resurface
- Broken threads for valve cover
- Exhaust Manifold/ Header studs bolts breaking easy fix
- head resurfacing in new orleans
- Gsr block / B16a head
- RSMachine 84.5mm B20 piston rings part number?
- Is this a cracked cylinder sleeve?
- D15B2 / civic 90' Only one cylinder dowel pin?
- Coolant Leak At Head Gasket - B18C1
- bronze valve guide reaming
- B16 head repairable? Deep pit and dent along combustion chamber
- block guard question (not typical Q!)
- Need help!!..I'm still learning
- B18C1 Oil Strainer/Pick-Up Tube Gasket
- First engine start of build
- Initial Start Up - Break In Rings? Or Burp Cooling System? B18C1
- b18b crank = b20b Crank???
- Gsr block
- I need to used smaller exhaust manifold studs
- D16 h-beam rod oil hole?
- Gouge/crack in block???
- B18c . Ferrea roller rockers / sk2 pro2
- hand turning b16
- Gsr head 5.550' milled keep or trash?
- B18b resurfaceing
- Valve spring retainers
- Does J35 in Ridgeline have FRM sleeves?
- f20b build
- Piston weight question
- Excess oil smoke after J35 rebuild
- 97 gsr main bearing colors
- D16 p08 head surface control
- Head Gasket: Block/Head surface roughness and other Q's
- Bore vs Sleeve vs Interlocking Sleeves
- Need some expert advice
- Need advice block decked to much and pistons stick out
- b18a1 first start
- Valve to piston clearance
- D series lma noise problem
- Help identifying valve spring max lift/coil bind
- looking for you valve seat angle tuners out there
- Wagon Rt4wd Turbo Rebuild
- Will a 95ls rebuild kit work on a 97ls that I am converting to obd1?
- Front and Rear Engine Seal Install - Dry, RTV, or Oil?
- How much are these parts worth?
- Engine builders in nj
- D16y8 vtec pin rocker question (speedfactory pins)
- D16 TDC valves open?
- MAIN AND ROD BEARING H23A VTEC
- piston c-clip size b16 build
- help with a rebuild
- d16z6 wont start after peel out
- d16z6 weird rear main seal housing?
- B-series valve recommendations
- B series LS crankshaft 10-20whp?
- Replacement D16Z6 Rocker Arm Assembly
- Piston to valve clearances?
- Is this ok for the main bearing notch?
- Piston ring gap for arias pistons
- piston ring gap question
- Small question on bearing sizing
- help modding b18a1 advice please
