b16a2 compression test question
Old Apr 28, 2016 | 03:31 PM
elnene_2012's Avatar
Default b16a2 compression test question
i have a b16a2 with 133,100miles head has skunk2 tuner1 cams ... i did a compression test due to little smoke coming out the exhaust sometimes when vtec kick in not all the time ... also when im at a stop sign long smoke for 2 seconds then goes away all 4 cylinder dry test at 210psi across.. and wet with little oil at 225psi does this seem right or is there something wrong with the piston rings ??
Old Apr 28, 2016 | 04:24 PM
2kdrift's Avatar
Default Re: b16a2 compression test question
sounds very good, main thing you are looking for is consistency between cylinders
humboldt_skim
May 31, 2008 08:18 AM
sik96teg
Feb 29, 2008 06:36 AM
P@@RB@Y
28
Nov 9, 2005 06:59 PM
Sport_Injected
Aug 25, 2004 09:21 PM
