PDA
View Full Version : Engine Machining & Assembly
Pages : [1] 2 3 4 5
  1. D17A6 Ticking After Rebuild?
  2. D16 bearing color matching
  3. got a non vtec sohc zc and cant figure out timing
  4. B18c1 but no Main Caps
  5. timing belt
  6. B18b1 swap to b18b1!!
  7. d16y8 first rebuild
  8. Valves - Sizing N/A vs. Bosst
  9. H22A2 excessive intake camshaft end play
  10. ARP bolts and stock flywheel question about fitment
  11. F22B2 Cracked Deck Between Sleeve
  12. B16a2 head
  13. 800hp build thread
  14. HELP!!! TIMING BELT KEEPS SKIPPING ON CAM GEARS
  15. Rattling noise only under load – Honda CR-V 2.2 i-CTDi (2008)
  16. D16Z6 Rocker Shaft Assembly Advise
  17. Is this journal on crankshaft repairable?
  18. B20 Vtec Clearances trouble
  19. 96 B18cr Rebuild
  20. B16 - All small parts needed?
  21. D16 won’t start after assembling
  22. 1986 Honda crx exhaust????
  23. P8R head 6.5mm stim guides to 5.5mm Vtec guides
  24. Base map question
  25. 96 vtec accord ex
  26. Is there a cylinder head assembly guide?
  27. Valve Stem Height Question H22
  28. Dilemma of a 2004 Element AWD k24a2 swap with 4speed AT
  29. Need a Double Check of my Bearing Color Order
  30. First B series build. Can anyone tell me the thread pitch of opening?
  31. Piston to wall tolerance and cross hatch longevity
  32. Rotating assembly balancing, weakened flywheel??
  33. 2016 Pilot engine swap
  34. Quick question
  35. Crazy k series build need help (first build)
  36. First start tons of blue/white smoke
  37. Jdm ITR timing belt fit USDM ITR?
  38. JSR Engines any good?
  39. Machine Shops Houston
  40. Overheated, 9th gen R18Z4, new headgasket or new engine ?
  41. i need a straight forward answer
  42. Bolt specs
  43. F20b piston help
  44. B16a2 intake port missalignment
  45. Where to buy OEM main bearings?
  46. Questions about calculating compression
  47. V2v pro1 h22
  48. p75 cylinder head variants?
  49. ARP studs installed with oil in threads?
  50. First timer rebuild 2000 d16y7 240k
  51. B16/18 crankshaft specs
  52. Advice on main bearing clearances?
  53. Recommended aftermarket brands for engine mounts?
  54. Overtorqued my main bearing cap bolts by 9ibs, am I okay?
  55. B16 head leaking oil at intake manifold
  56. Oil Pump question
  57. D16z6 Wear
  58. Could the dye engine machinists use cause a head gasket failure? From being there
  59. Shop for Valve Job
  60. Engine build shop in SC/NC?
  61. Crack in the block of B18B1
  62. Replace valve guides for new valves? (turbo b16a)
  63. H22a4 Mild Build, Piston Choice
  64. Need help with choosing bearings
  65. Questions about Machining for a d16z6 (and general building)
  66. head bolt check
  67. Piston help
  68. K20a3 camshafts into a K20z2?
  69. Skink2 pro series cam gears
  70. Engine blocks with coolant drains?
  71. Michigan machine shops still in business?
  72. Cam and crank housing scratches
  73. Block surface finish
  74. Sending my block for css 81mm .5 overbore
  75. Rod Bearing Clearance Question
  76. Machining and Gasket Questions
  77. Should I save Engine Block and Frame ?
  78. HELP Engine timing marks wrong
  79. Acl over oem main bearing advantages
  80. Reuse or Replace B18C1 Main Bolts?
  81. Nippon Racing Pistons coating wall clearance
  82. D16 pistons D15 block?
  83. B18b1 from 99 integra ls. Leaking intake valve.
  84. Overboring d16y7
  85. Saving a Block with Thrust Bearing Failure
  86. Intake and Exhaust Rocker Arm Interchangeable? (B-SERIES)
  87. Skunk2 Pro1 camshaft users/tuners-HELP
  88. NPR piston ring gap
  89. Pistons says 81.5. Mic’d. 81 flat. the balls c meant 81:5. Is it true 81.5?
  90. 2019 honda piolt won't start after accident
  91. Acura rdx 2014 engine swap
  92. cylinder seal civic d17 turbo
  93. Need to find A engine 2002 Honda Civic LX
  94. 2015 Accord 2.4 K24W1 cylinder head resurfacing concerns / specs
  95. Need help calculating basic cr
  96. 2003 Pilot AC Compressor Clutch help
  97. Which APR bolts to i need for b18b1?
  98. Need help do my bearing look new? I think I got scammed.
  99. B18c1 block. B18b1 crank
  100. Inconel/super alloy exhaust valve + BC springs and retainers
  101. Electrical Help!!!!!!!!!!!!!!!B18
  102. Experiences with Bad Guys oil pump?
  103. Is Dan Benson Machine still going?
  104. Pro 3 bseries cam question
  105. Boring my Stock Head Gasket
  106. Need Help B18 swap in 97 coupe
  107. B20v help with some hoses
  108. Turbo B16 | Daily driven | Bearing clearances
  109. D16y7 piston to wall clearance
  110. Insane experience with local Machine Shop!
  111. 0 oil pressure at idle
  112. Rebuilding B18b - does this look ok?
  113. B20b vs b18b1 block
  114. Sketchy machine shop
  115. Ek hatch with b20v
  116. Idle rpm jumping
  117. Is this head usable?
  118. Rod bearing and main bearing identification
  119. '07 civic. tapped hole crooked into block
  120. J35A6 Piston Polishing
  121. Bearings: But my intuition says no!
  122. B20v wire help
  123. B20b vtec turbo engine block build
  124. Scored H22 cylinder
  125. Fully build b20v
  126. Timing chain cover install
  127. Making D15b2 with D16Z5
  128. Have I messed up my crank?!
  129. JDM F22B DOHC - Engine Internals
  130. A Stupid Question - Line Boring B16 Mains for Aftermarket Girdle?
  131. Can someone explain why Jay is doing this? Lube UNDER the main bearings?!
  132. F23A1 Cylinder Head Dilemma
  133. H22 nicked/damaged rod journall any good?
  134. Needing to order main/rod bearings but I'm LOST!!!!!!!!
  135. What is the oldest B18C GSR
  136. Cylinder Wall Damage. Need opinions!
  137. Have questions on parts for my D series
  138. Cam card specs vs Actual Readings
  139. Found True TDC, Cam Gears Don't Line Up
  140. oil pump leaking
  141. What do I need when putting d16a6 pistons on a y7 block, going mini-me.
  142. Combustion chamber damage. . Fixable?
  143. Spotty Difficult to turn engine by hand
  144. B series ?
  145. What type of piston should I use with eagle h beam full floating Connecting rods
  146. Is this a broken piston skirt?
  147. Ring gaps
  148. Using 30w vs 10w40 when torquing rod bolts
  149. Generic question: crank vs piston steering
  150. Is my b18c from a type r or gsr
  151. Turbo B series Tuning Issues
  152. ARP Head Stud Alternatives
  153. Oil cooler joint fitting b18c
  154. crank balancing?!?
  155. S2 racing B series identify cams
  156. F22b engine rebuild question
  157. Help me please!
  158. Golden eagle fuel rail fittings??
  159. B Series engine on a Mercedes 190e
  160. Gasket kit
  161. Weird main bearing wear pattern on B20.
  162. B series Crank Pulley
  163. Low oil pressure troubleshooting
  164. Assembling a B20B4 w/Z2 internals
  165. Frustrations with Tapered ring compressor.
  166. GSR Main bearing "Roll in" Help!
  167. H23A + Nippon Racing pistons P2W ?
  168. Threaded core plug sealant
  169. Low oil pressure on fresh GSR
  170. K20A piston pin offset
  171. F22A6 oil pump passages?
  172. Exhaust stud stuck in the block
  173. Please help with the torque spec on an engine bolt
  174. Del Sol OEM Valve Springs
  175. Ti retainer mystery??
  176. Can not find replacement Yellow main bearings
  177. King Racing bearings clearance for turbo B16A2
  178. PR3-3 Cam Caps on PR3-2
  179. B20B .001 main bearing clearance. What to do? Where can i find undersized bearings.
  180. What is thus gunk on the outside of my cylinder walls
  181. Is this hole supposed to be there?
  182. Do my pistons look okay?
  183. b20b head rebuild for performance
  184. B16a Stripped Valve Cover Bolt Threads
  185. Help with B18 build
  186. Starting brand new engine with non detergent
  187. Does anyone know why tf i have an extra injector plug lol
  188. Head studs
  189. Compression Test Results on Rebuilt Engine
  190. Rebuilt Engine Smoking
  191. B20z b18c gsr jdm head p2v
  192. Re-ring and rods/mains while sealing oil leak?
  193. how much is to much
  194. What is this line coming from the oil filter?
  195. timing belt guides?
  196. B20 VTEC Stock Piston P2V
  197. Starter solenoid connector broke into solenoid??
  198. Question about GSR AEBS Intake Manifold
  199. How does this engine look?
  200. ATI super damper zero mark
  201. Lsvtec turbo
  202. Any Main bearing removal tips for ftpowell97's H22?
  203. Please help.. Will a d16z6 oil pick up and windage tray fit a d16a6
  204. Reman engine off eBay leaking coolant on first start?
  205. Piston ring end gap B20B (84mm)
  206. Cam belt too loose?
  207. Timing belt touching engine
  208. Can you tell if this is aftermarket sleeve or stock
  209. Camshaft Identification
  210. Turning down rod big end?
  211. B20 timing gear question
  212. Do these p2v clearances make sense?
  213. B16B Identification
  214. Horepower
  215. B16B Camshaft Lobe Height Specs?
  216. Is this block sleeved
  217. lsvtec timesert fail
  218. Wheel Hub Assembly
  219. B-series Hybrid Head Gasket Oil Leaks
  220. J30A4 bearing selection
  221. B20 Block Sleeving - Not your conventional method!
  222. B20VTEC - B16 Rods on B20 Crank
  223. Diy head porting dimpling question
  224. Rod bearings offset? SOHC
  225. Timming belt and tensioner question for a d16a6/z6
  226. Re-Torquing ARP Head Studs?
  227. H-series Bearing Calculation - ADVANCED TECHS
  228. Cams from a different head?
  229. 93 Delsol with B16b swap
  230. Anybody swapped a crankshaft from a different engine?
  231. Can this be fixed with resurfacing?
  232. Jumped timing AND rod knock??? At the SAME time???
  233. Any reviews on Blox MLS head gasket?
  234. H22A (euro R) Rebuild coming up
  235. main and rod oil clearances
  236. Deck Height - How is it measured?
  237. Bolt specs for B16A2 engines
  238. Urgent! Need help.
  239. Ring Gap question
  240. Question. Gsr 81.5 with ls crank = 1900cc?
  241. B series manual timing tensioner on D series
  242. b18b with a b16 crank thrust washers
  243. Is anybody here a J-series head expert?
  244. D15b2 with y5 head
  245. Check out my crank
  246. D15 External Dimensions
  247. Use the same sized engine bearings that were origionally used???
  248. Trouble in 97
  249. Turn GSR into Type-R?
  250. Is my crankshaft in spec
