Too much bearing clearance??
So I'm in the middle of building a b20 block and after measuring both my main bore and crank shaft. I'm left with .004 bearing clearance.
Have in mind that the crank is standard spec but the main bore was bored out which is probably why my clearance is out of (spec .002).
Would I be ok running .004 with ACL bearings???
Please help thanks
Please help thanks
Re: Too much bearing clearance??
.004 overall right? (.002" per side)
That's a ton of clearance either way. What are you measuring with?
I don't even run that much clearance in a blown alcohol engine with straight 50wt oil
