D16y7 with d15b8 head
Old Jan 21, 2016 | 10:32 AM
Joshuapinkley's Avatar
Icon4 D16y7 with d15b8 head
Need to know if anyone has tried this I have a new d15b8 head for cheep and have been looking at specs it's going to raise compression and its a better intake just trying to see if anyone has done it
Old Jan 21, 2016 | 12:32 PM
Pro-SeriesFab's Avatar
Default Re: D16y7 with d15b8 head
run, don't walk, from any of the 8v heads . . . they are junk and a complete waste of time.
b8s don't even have roller rockers like the b6s did.
Keep the y7 head and have it milled a bunch if you want to raise compression that way
Old Jan 21, 2016 | 01:48 PM
The d15 head has Been done and have u tried it
Old Jan 21, 2016 | 01:56 PM
And the d15b8 is a 16v head
Old Jan 21, 2016 | 03:37 PM
If you have a 16 valve head, it most certainly is not a b8.
d15b8s came in the CX models and were the repackaged HF models . . . fuel economy above all else, including HP.
Old Jan 22, 2016 | 04:02 AM
That's what I pulled it off of.
Old Jan 22, 2016 | 05:34 AM
Then someone, somewhere along the way swapped to another head before you got the motor.
Check the code on the head on the exhaust side.
D15b2- PM3 DX
D15b6- PM8 CX
D15b7- PM9 DX
D15b8- PM8 CX
D15z1- PO7 VX
D16a6- PM3 Si
D16z6- PO8 EX
D16y5- P2J VX
D16y7- P2F DX
D16y8- P2J EX
Old Jan 22, 2016 | 07:01 AM
It's the pm3-8
Old Jan 22, 2016 | 09:37 AM
It's the pm3-8
the pm3s are the obd-0, 16v, 88-91 heads.
It could be off a b1, b2, or a6 . . . someone realized that the b8 head was a boat anchor and went ahead and swapped the head out for you
Old Jan 22, 2016 | 09:39 AM
How would it do on a d16y7 block
Old Jan 22, 2016 | 11:02 AM
It would fit and work just fine. The only differences I know of revolve around the relocation of the spark plug to enter from the exhaust side and the spark plug boss being changed from part of the casting before 1995 to the metal shield the VTEC heads have/had.
From what I've seen, the ports in the non-vtec heads look the same but I don't have any besides a pm3 here in front of me
Old Jan 22, 2016 | 06:20 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
PM3 has also been found on the obd1 D15B7 heads as well as the D16A6 Heads. I've also seen it on JDM D15B heads.
D15B7
93 LX auto---------------------------------PM9-6 (Year Code 9/2)
94 DX 5sp----------------------------------PMS-1
94?----------------------------------------PM3-12 (Year Code 9/3)
95 CX--------------------------------------PM9-3 (Year Code 9/4)
95 DX 5sp----------------------------------PM9-5
95 DX--------------------------------------PM3-5 (Year Code 9/5)
95 DX--------------------------------------PM9-3 (Year Code 9/4)
95 LX Sedan 5sp----------------------------PM9-2
D16A6
88?----------------------------------------PM3-8
88 Si--------------------------------------PM3-11 (Year Code 8/8)
88 RT Auto---------------------------------PM3-7
90 Si 5sp----------------------------------PM3-1
90 Si 5sp----------------------------------PM3-4
The B7 and A6 heads share the same specs with the exception of valve springs and cam shafts. Even there I heard in 95 they ran out of B7 springs so used the A6 springs instead as they are the same size and height, just a little stiffer.
It's good to know the old B2 is the same head.
JDM_EK_JOE
Apr 20, 2006 06:33 AM
digital sol
Feb 1, 2005 07:58 AM
Ignitecivic
Dec 7, 2003 09:23 AM
