B18c4 swap problem
Old Nov 11, 2015 | 10:03 PM
Glyran's Avatar
Default B18c4 swap problem
Hey Guy's
New at this forum but not new in the Honda world.
I have swap a b18c4 engine to My 1997 del sol and now i have big problems.
I dont have any idle and the engine's runs and hack on 1500rpm. And i think the engine's goes pretty good otherwise. Maybe not 100% good but it goes to drive.
But here is the strange problem. When i pump the brake i get the idle to 600-700 rpm. And when i take off the vaccum line to the brake servo the cars go up to 1500 rpm in idle and "hack" / goes bad there.
I have try other maps sensor, tps, electric signals.
I did have obd2a in My d16y8 engine and have now a converter from that to obd1 p28 ECU.
I run on the b18c4 Europa loom
What can the problem was
Old Nov 12, 2015 | 12:52 PM
Dark_Teg's Avatar
Default Re: B18c4 swap problem
If the brake pedal is effecting idle then I would check the brake booster for a vacuum leak.
Old Nov 13, 2015 | 07:01 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Originally Posted by Glyran
b18c4 engine
A SOHC ECU running a DOHC engine....
I don't think any loom/wire harness is going to fix that.
I believe you need a P72 for B series motors.
Glyran
Nov 13, 2015 10:40 AM
Redprelude98
25
Nov 30, 2014 02:15 PM
blue_hatch
Feb 8, 2011 11:09 PM
Cambocheen!
Mar 23, 2009 12:09 PM
slim9300
May 10, 2004 07:04 PM
